17267 Discussions
Arria V Formal verification problems
Hi everyone,
I want to do a formal verification of a project where i use a Arria V FPGA, and to do this i'm planning to use Encounter Conformal Software, that is a Cadence tool But i'm not having much success.
I'm trying to follow these step by step that i found:
http://quartushelp.altera.com/14.1/mergedprojects/eda/verification/conformal/eda_pro_lec_setup.htm
To do this verification, i need to generate 2 files for Encounter Tool: a verilog output file (.vo) and a verilog quartus mapping file (.vqm). I generated the .vo without any problems but when i try to generate the .vqm, i get the following error: "Quartus II does not support the generation of .vqm for this family"
Ps: In the link above, Altera says that Arria family is supported for this flow.
Did anyone else already have this problem?
I suggest raising a mysupport ticket on the altera website. Sounds like a tool bug or documentation error.
--- Quote Start ---
--- Quote End ---
I will try this.
Thank you.
