17250 Discussions
Assign all zeroes to unsigned
Hi, I want to assign all zeroes to an unsigned signal. I've been using ( others => '0' ) for STD_LOGIC_VECTOR signals, but when i attempt to do the same for unsigned, i get an error:
Error (10500): VHDL syntax error at top.vhd(222) near text "others"; expecting "(", or an identifier ("others" is a reserved keyword), or unary operator
Does this only work at the declaration of the signal? Can I use it within my process on reset for example? if not, is there another easy way to set a signal to all zeroes? ( i am trying to avoid typing it all out since I plan to change the size of these signals between subsequent runs. )
Unsigned is a base 10 nuber without a sign. So assigning 0 should work.
unsigned_sig <= 0;
--- Quote Start ---
unsigned_sig <= 0;
--- Quote End ---
You can't do that because 0 is an integer. Also note that unsigned is binary, not base 10.
You need to convert to an unsigned from an integer.
Op <= to_unsigned(0, op'length);
This should also work.
Op <= (others => '0');
The ops problem sounds like a syntax error. Why not post the actual code?
unsigned type accepts (others => '0');
it also accepts comparing with integer type but not assigning to integer type
--- Quote Start ---
--- Quote End ---
Hi, I have no idea what the problem was but i reverted my code to a previous save and made my changes one by one and it worked! i wish i knew what caused the problem in the first place, but i cant even seem to reproduce it now.
