17267 Discussions
Assigning value to 7 bits output buffer?
I'm doing a Moore FSM, and the outputs are 7 bits buffers (declared as such:
sum: out STD_LOGIC_VECTOR(6 down to 0);
When writing the output logic, I wrote:
when S2 => sum <= '0001010';
but that gives me an error for each of these instances. What would be the correct syntax for what I'm trying to do?
Thanks!
sum <= "0001010" WHEN S2 = '1';
Any number that uses more than 1 bit requires double quotes. If that is supposed to be a hex number (not clear but guessing it's binary), you would add an x (x"0001010").
--- Quote Start ---
--- Quote End ---
Since 'sum' is a 7-bit value and x"0001010" represents a 28-bit value (which wouldn't work), stick with sstrel's first solution.
Cheers,
Alex
' is used for single characters
" is used for strings
You need to use "
Whoops, missed the 7-bit part! Yes, just "0001010".
