Still trying to fully understand TimeQuest for proper IO constraining... I'm using a source-synchronous output scheme, where the output clock is generated from a DDR FF. Using fast output register to force FF in IOE. With the required set_output_delay -min & -max, the fitter can't meet the timings for some pins. But if I manually set some delays (output delays D5 & D6 in Stratix 3 IOE) on the clock output and on other outputs, then my constraints are met. Interface is running at 200MHz so I would like to minimize the skew between outputs (currently I get near 900ps - too much for my taste). Any way to let the fitter automatically choose the proper output delay to meet the constraints? Thanks! François Choquette (way more TimeQuest questions to come)Link Copied
