17252 Discussions
Warning (14130) Reduced register with stuck
Hi, I try to simulate follow code, but when I simulate it, Quartus II says:
Warning (14130): Reduced register "PWM_Accumulator0[6]" to stuck with stuck data_in port to stuck value GND
I dont know why, but could it not simulate it... Please, I need your help!!!
VHDL code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY RAM IS
PORT
address : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
clock : IN STD_LOGIC ;
data : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
start : in std_logic;
clockPWM : in std_logic;
reset : in std_logic;
enable : in std_logic;
PWM_out0 : out std_logic;
PWM_out1 : out std_logic;
motor1_dir : out std_logic;
motor1_esq : out std_logic;
motor2_dir : out std_logic;
motor2_esq : out std_logic;
sensor1 : in std_logic;
sensor2 : in std_logic
END RAM;
ARCHITECTURE SYN OF ram IS
signal sub_wire0 : std_logic_vector (7 downto 0);
signal PWM_Accumulator0 : std_logic_vector(8 downto 0);
signal PWM_Accumulator1 : std_logic_vector(8 downto 0);
signal q0 : std_logic_vector(7 downto 0) := "00000000";
signal q1 : std_logic_vector(7 downto 0) := "00000000";
signal q2 : std_logic_vector(7 downto 0) := "00000000";
signal q3 : std_logic_vector(7 downto 0) := "00000000";
signal PWM_in0 : std_logic_vector(7 downto 0) := "00000000";
signal PWM_in1 : std_logic_vector(7 downto 0) := "00000000";
signal andclk0 : std_logic_vector(7 downto 0) := "00000000";
signal andclk1 : std_logic_vector(7 downto 0) := "00000000";
signal andclk2 : std_logic_vector(7 downto 0) := "00000000";
signal andclk3 : std_logic_vector(7 downto 0) := "00000000";
signal data_en0 : std_logic;
signal data_en1 : std_logic;
signal data_en2 : std_logic;
signal data_en3 : std_logic;
signal and0_1 : std_logic;
signal and0_2 : std_logic;
signal and1_1 : std_logic;
signal and1_2 : std_logic;
signal and2_1 : std_logic;
signal and2_2 : std_logic;
signal and3_1 : std_logic;
signal and3_2 : std_logic;
signal sensor_in1 : std_logic;
signal sensor_in2 : std_logic;
signal motor1_on : std_logic;
signal motor2_on : std_logic;
COMPONENT altsyncram
GENERIC (
clock_enable_input_a : STRING;
clock_enable_output_a : STRING;
intended_device_family : STRING;
lpm_hint : STRING;
lpm_type : STRING;
numwords_a : NATURAL;
operation_mode : STRING;
outdata_aclr_a : STRING;
outdata_reg_a : STRING;
power_up_uninitialized : STRING;
ram_block_type : STRING;
widthad_a : NATURAL;
width_a : NATURAL;
width_byteena_a : NATURAL
PORT (
wren_a : IN STD_LOGIC ;
clock0 : IN STD_LOGIC ;
address_a : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
q_a : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
data_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0)
END COMPONENT;
BEGIN
q <= sub_wire0(7 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP (
clock_enable_input_a => "BYPASS",
clock_enable_output_a => "BYPASS",
intended_device_family => "Cyclone II",
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram",
numwords_a => 32768,
operation_mode => "SINGLE_PORT",
outdata_aclr_a => "NONE",
outdata_reg_a => "UNREGISTERED",
power_up_uninitialized => "FALSE",
ram_block_type => "M4K",
widthad_a => 15,
width_a => 8,
width_byteena_a => 1
PORT MAP (
wren_a => wren,
clock0 => clock,
address_a => address,
data_a => data,
q_a => sub_wire0
process(enable, reset, address, wren, sub_wire0)
begin -- ||byte flags motores||
and0_1 <= not wren; -- habilitado para leitura
and0_2 <= address(0) and not address(1) and not address(2); -- end "001"
data_en0 <= and0_1 and and0_2;
andclk0(0) <= data_en0 and sub_wire0(0);
andclk0(1) <= data_en0 and sub_wire0(1);
andclk0(2) <= data_en0 and sub_wire0(2);
andclk0(3) <= data_en0 and sub_wire0(3);
andclk0(4) <= data_en0 and sub_wire0(4);
andclk0(5) <= data_en0 and sub_wire0(5);
andclk0(6) <= data_en0 and sub_wire0(6);
andclk0(7) <= data_en0 and sub_wire0(7);
and1_1 <= not wren; -- ||byte flags sensores||
and1_2 <= not address(0) and address(1) and not address(2); -- end "010"
data_en1 <= and1_1 and and1_2;
andclk1(0) <= data_en1 and sub_wire0(0);
andclk1(1) <= data_en1 and sub_wire0(1);
andclk1(2) <= data_en1 and sub_wire0(2);
andclk1(3) <= data_en1 and sub_wire0(3);
andclk1(4) <= data_en1 and sub_wire0(4);
andclk1(5) <= data_en1 and sub_wire0(5);
andclk1(6) <= data_en1 and sub_wire0(6);
andclk1(7) <= data_en1 and sub_wire0(7);
and2_1 <= not wren; -- ||byte duty cycle motor1||
and2_2 <= not address(0) and address(1) and address(2); -- end "011"
data_en2 <= and2_1 and and2_2;
andclk2(0) <= data_en2 and sub_wire0(0);
andclk2(1) <= data_en2 and sub_wire0(1);
andclk2(2) <= data_en2 and sub_wire0(2);
andclk2(3) <= data_en2 and sub_wire0(3);
andclk2(4) <= data_en2 and sub_wire0(4);
andclk2(5) <= data_en2 and sub_wire0(5);
andclk2(6) <= data_en2 and sub_wire0(6);
andclk2(7) <= data_en2 and sub_wire0(7);
and3_1 <= not wren; -- ||byte duty cycle motor2||
and3_2 <= address(0) and not address(1) and not address(2); -- end "100"
data_en3 <= and3_1 and and3_2;
andclk3(0) <= data_en3 and sub_wire0(0);
andclk3(1) <= data_en3 and sub_wire0(1);
andclk3(2) <= data_en3 and sub_wire0(2);
andclk3(3) <= data_en3 and sub_wire0(3);
andclk3(4) <= data_en3 and sub_wire0(4);
andclk3(5) <= data_en3 and sub_wire0(5);
andclk3(6) <= data_en3 and sub_wire0(6);
andclk3(7) <= data_en3 and sub_wire0(7);
if reset='1' then
q0(0) <= '0';
q0(1) <= '0';
q0(2) <= '0';
q0(3) <= '0';
q0(4) <= '0';
q0(5) <= '0';
q0(6) <= '0';
q0(7) <= '0';
q1(0) <= '0';
q1(1) <= '0';
q1(2) <= '0';
q1(3) <= '0';
q1(4) <= '0';
q1(5) <= '0';
q1(6) <= '0';
q1(7) <= '0';
q2(0) <= '0';
q2(1) <= '0';
q2(2) <= '0';
q2(3) <= '0';
q2(4) <= '0';
q2(5) <= '0';
q2(6) <= '0';
q2(7) <= '0';
q3(0) <= '0';
q3(1) <= '0';
q3(2) <= '0';
q3(3) <= '0';
q3(4) <= '0';
q3(5) <= '0';
q3(6) <= '0';
q3(7) <= '0';
elsif enable'event and enable='1' then
q0(0) <= andclk0(0);
q0(1) <= andclk0(1);
q0(2) <= andclk0(2);
q0(3) <= andclk0(3);
q0(4) <= andclk0(4);
q0(5) <= andclk0(5);
q0(6) <= andclk0(6);
q0(7) <= andclk0(7);
q1(0) <= andclk1(0);
q1(1) <= andclk1(1);
q1(2) <= andclk1(2);
q1(3) <= andclk1(3);
q1(4) <= andclk1(4);
q1(5) <= andclk1(5);
q1(6) <= andclk1(6);
q1(7) <= andclk1(7);
q2(0) <= andclk2(0);
q2(1) <= andclk2(1);
q2(2) <= andclk2(2);
q2(3) <= andclk2(3);
q2(4) <= andclk2(4);
q2(5) <= andclk2(5);
q2(6) <= andclk2(6);
q2(7) <= andclk2(7);
q3(0) <= andclk3(0);
q3(1) <= andclk3(1);
q3(2) <= andclk3(2);
q3(3) <= andclk3(3);
q3(4) <= andclk3(4);
q3(5) <= andclk3(5);
q3(6) <= andclk3(6);
q3(7) <= andclk3(7);
end if;
PWM_in0(7) <= q2(7);
PWM_in1(7) <= q3(7);
end process;
process(clockPWM, PWM_in0, PWM_in1, sensor1, sensor2)
begin
if rising_edge(clockPWM) then
PWM_Accumulator0 <= ("0" & PWM_Accumulator0(7 downto 0)) + ("0" & PWM_in0);
PWM_Accumulator1 <= ("0" & PWM_Accumulator1(7 downto 0)) + ("0" & PWM_in1);
end if;
end process;
motor1_on <= q0(0);
motor2_on <= q0(1);
motor1_dir <= q0(2);
motor1_esq <= not q0(2);
motor2_dir <= q0(3);
motor2_esq <= not q0(3);
sensor_in1 <= q1(0) and sensor1;
sensor_in2 <= q1(1) and sensor2;
PWM_out0 <= PWM_Accumulator0(8) and start and not sensor_in1 and motor1_on;
PWM_out1 <= PWM_Accumulator1(8) and start and not sensor_in2 and motor2_on;
END SYN;
--- Quote Start ---
--- Quote End ---
The reason is in your arithmetic. Only PWM_in0(7) can be different from zero, thus PWM_Accumulator0(6 downto 0) are stuck to "000000". Please don't expect a comment, where the problem is located in your code.
alright, thank you
