17240 Discussions
Avalon I2C (Master) Intel FPGA IP
gomezramones
Hi, I am trying to use Avalon I2C (Master) Intel FPGA IP in Qsys but I am not sure how to use the register in this module since there are Control Register to configure the speed or enable the core. ISER to enable ACK and others.
Just to make sure, signals scl_in and sda_in is when the I2C module is reading and scl_oe and sda_oe when is writing, right? In other words, it is the same if I would declare sda :inout and scl : inout?
JingyangTeh_Altera
Hi
To interface with the IP, you could include the library and interface with the IP with the following function calls.
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/fpga-i2c-host-core-api.html
You could refer to the link below on the pin definition.
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/interface-13852.html
There are more information of the IP in the link below:
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/fpga-i2c-host-core.html
Jingyang, Teh
JingyangTeh_Altera
Hi
Any update on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi
Since a solution have been provided and no feedback was received, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
