17252 Discussions
Avalon MM Master Interface Template
Hey,
my goal is to access ddr3 Memory from the outside of my Qsys system where the DDr3 Controller is implemented. Has anyone a Template for a Master interface to access the memory from outside the qsys system or is it better to design my own IP core with my VHDL code that i am able to connect everything in the qsys environment.
thanks Rene
I'd go for own core. I've used it for my DMA.
What template you used for your own core? can u upload them or link them?
Rene
In Qsys: Add new component and there will be templates menu. Although, I used signals from manual, no need for template.
Hey tanks for your quick reply,
i found the template and get a new component. is there any example vhdl/ verilog file for the usage of this component. I think about a small file that read/write data with this interface to a ddr3 ram.
Rene
as always - read the documentation, all signals are clearly described and waveforms shown.
yeah but maybe someone done it before and is ready to share it with me.
thanks Rene
