Hello. Is there any way to set more then 2 inputs in AvST multiplexer component? When i set for example 3, the error appears:
Error: multiplexer_0: Channel isn't wide enough.
:confused:
Yes it is. Set a wider channel signal.
Oh, that was obvious :oops:. Thank you.
Topic Options
