Avalon-ST mux
Colaborador Distinguido II
1.501 Vistas
Hello. Is there any way to set more then 2 inputs in AvST multiplexer component? When i set for example 3, the error appears:
Error: multiplexer_0: Channel isn't wide enough.
:confused:
0 kudos
2 Respuestas
721 Vistas
Yes it is. Set a wider channel signal.
721 Vistas
Oh, that was obvious :oops:. Thank you.
Responder
