17254 Discussions
Avalon Verification IP example avlmm_1x1_vhdl not working in Questa Intel FPGA Edition
powARman
I encountered some issues with the Avalon-MM BFM we use in simulations after upgrading our project to Quartus 21.1. The BFM is not behaving as expected, accesses to the bus are not finished.
To verify that this is not an issue of our implementation, I tried running the avlmm_1x1_vhdl example from the Avalon Verification IP Suite both in Modelsim Intel FPGA Edition 2020.1 (part of Quartus Standard 20.1) and Questa Intel FPGA Edition 2021.2 (part of Quartus Prime Standard 21.1). I also tried later Quartus Prime versions, but they include the same version of Questa, so there is no difference in using those.
In Modelsim everything works fine, where in  Questa the access to the BFM are not finished as expected, the simulation just "hangs" during the second access, see screenshots below. The main difference I see is the master_0/events and slave_0/events signal, which is updating every clock cycle in Modelsim, but is updating much less in Questa.
Is this a known issue of Questa? Is there anything to configure to get around this?
Best regards
Andreas
ShengN_Intel
Please follow the debug steps below:
1.In the run_simulation.tcl script, add this command set USER_DEFINED_ELAB_OPTIONS -novopt to simulate without optimization.
2.Then, in the command prompt type vsim -suppress 12110 to invoke the Questa simulator GUI.
3.Then, do run_simulation.tcl script again and should see the full complete simulation.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Sheng
powARman
Hi Sheng,
I tried it and it works fine now. Thank You
IgorKa
Hello.
The newest revision of QuestaSim does not accept -suppress switch.
The problem is that the QuestaSim optimizer flashes the delta-events. If you are using multilanguage QuestaSim, the solution is to make little tunning in the "altera_avalon_mm_master_bfm_vhdl_wrapper.sv" file:
1) Change timescale resolution `timescale 1ps / 1ps
2) In line 519 add "#1", like:
always @(mm_master.signal_all_transactions_complete) begin
events[MM_MSTR_EVENT_ALL_TRANSACTIONS_COMPLETE] = 1;
#1 events[MM_MSTR_EVENT_ALL_TRANSACTIONS_COMPLETE] <= 0;
end
It will solve the problem. You can save the custom file and each Platform Design reconfiguration, just replace the "altera_avalon_mm_master_bfm_vhdl_wrapper.sv" file with a patched one.
Good Luck
Igor
powARman
Hello @IgorKa,
I tried your proposal, I had to add the #1 to all the events to get it working, and I also had to apply the same changes to the slave wrapper file. After doing that, I could run my simulations successfully without having to disable optimizations. Thank you very much.
I created two sed commands to do the replacement automatically after generating the files:
sed -i "s/\(^.*timescale 1\)ns\( *\/ *1\)ns\(.*$\)/\1ps\2ps\3/g" avlm_avls_1x1/simulation/submodules/*_wrapper.sv
sed -i "s/\(^.*\)\(events\[.*\] *<= *0;\)/\1#1 \2/g" avlm_avls_1x1/simulation/submodules/*_wrapper.sv
Best regards
Andreas
