BRAM in QuartusII
How can I write a BRAM in Quartus?
I had been working with ISE and don't know how to define a BRAM in Quartus.
Check the "Quartus HDL coding guidelines" document.
If you write VHDL/Verilog that conforms to the templates described in it, Quartus will infer block ram.
If you want to it more manually, check Altera's "Internal Memory User Guide".
