17268 Discussions
BUG: Verilog 1.0*(2.0**N) const expression evaluates to 0 if N is a localparam
algofoogle
Is it fine to report Quartus Prime Lite bugs here?
I'm using Quartus Prime Version 22.1std.0 Build 915 10/25/2022 SC Lite Edition with no patches. I will try a newer version later.
Given this Verilog code:
localparam N = 12.0;
initial begin
  $display("%f %d", 1.0*(2.0*N),     1.0*(2.0*N));      // Two products.
  $display("%f %d", 1.0*(2.0**12.0), 1.0*(2.0**12.0));  // Product & power.
  $display("%f %d", 1.0*(2.0**N),    1.0*(2.0**N)); //BUG! Product & power.
  $display("%f %d",     (2.0**N),        (2.0**N));     // Power only.
end
 ...at compile-time the log includes these unexpected results:
Info (10648): Verilog HDL Display System Task info at raybox.v(104): 24.000000 24
Info (10648): Verilog HDL Display System Task info at raybox.v(105): 4096.000000 4096
Info (10648): Verilog HDL Display System Task info at raybox.v(106): 0.000000 0
Info (10648): Verilog HDL Display System Task info at raybox.v(107): 4096.000000 4096
 Notice that specifically 1.0*(2.0**N) gives an incorrect result (0) while the others work as expected. This problem also happens if assigning this expression to another localparam, or trying to use it in logic.
I tried other definitions of the localparam, too, including:
localparam real N = 12.0;
localparam integer N = 12;
localparam [3:0] N = 12;
SyafieqS
Thanks for the update. I will feedback this to developer for fix.
Let me know if there is any other concern on this.
Really appreciate the feedback.
SyafieqS
Have you tried this in Pro Edition or latest version as mentioned?
Does the value still reflect wrongly?
SyafieqS
Let me know if there is any update from previous reply
algofoogle
My apologies, I was unable to return to this for a while, but I've now tested in Quartus Prime Version 22.1.std.1 Build 917 02/14/2023 SC Lite Edition. The same issue exists, with exactly the same output.
This is the most recent version I can test, as I do not have a Pro license and version 23.1 hasn't been released as a Lite version yet.
SyafieqS
Thanks for your feedback. I will feedback this and request for a fix.
This might be taking sometime as developer is prioritizing critical case.
Let me know if there is any other concern.
