17255 Discussions
Basics - 2 inputs, 1 output + positive edges
Quartus II, version 10.1, Cyclone II.
I'm newbie in Verilog. I need a block:
module (input x1,x2, output reg Y);
if (positive edge of x1) Y=0;
if (positive edge of x2) Y=1;
I tried
"always @(posedge x2)
begin
zliczaj=1;
@(posedge x1) zliczaj=0;
end"
but i had error "multiple event control statements not supported for synthesis".
I tried
"always @(posedge clear)
zliczaj=1;
always @(posedge pelne)
zliczaj=0;"
but i had error "can't resolve multiple constant drivers for net 'Y' at ....".
How to do that?
--- Quote Start ---
I tried
begin
zliczaj=1;
end"
I tried
zliczaj=1;
zliczaj=0;"
How to do that?
--- Quote End ---
you should drive Y only on one clock edge. you better have a clk faster than x1 ,x2 then use x1 as enable to drive '0' on Y and use x2 as enable to drive '1' on Y (within the same clocked process). This will drive Y on the clk edge but not on x1,x2 edges. If you mean by x1 or x2 edge its transition fron 0 to 1 sample then you add extra logic as your enable.
You cannot have a signal being changed by two different processes. This would be the equivalent of having two registers with different clocks having their outputs tied together.
Generally you would use a clock signal for doing edge triggering. The signals you then wish to trigger off would be used as enables. IE.
