17253 Discussions
I can't compile my code to generate a PWM signal
Hi everyone
When I compile my code a problem with the syntax appears and I can't find the problem. The objective of my code is generate a PWM signal:
library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; use IEEE.std_logic_signed.all; use IEEE.std_logic_unsigned.all; entity pwm_generator is port( a, b: in bit_vector (31 downto 0); c: out bit); end pwm_generator; --The input 'a' means the frequency, of signal pwm, in binary. For example 1234Hz is 00000000000000000000010011010010Hz --The input 'b' means the duty cicle in binary. For example 27% is 00000000000000000000000000011011% --The output 'c' means the output of pwm signal. architecture logical of pwm_generator is variable t, e, a1, b1, f: integer; --The variable 't' means the period (in seconds) of pwm signal. --The variable 'e' means the time (in seconds) of the high level ('1') of the pwm signal. --The variable 'a1' means the decimal representation of the input 'a'. --The variable 'b1' means the decimal representation of the input 'b'. --The variable 'f' means the time (in seconds) of the low level ('0') of the pwm signal. begin a1 := to_integer(unsigned(to_stdlogicvector(a))); b1 := to_integer(unsigned(to_stdlogicvector(b))); t := 1/a1; e := t*b1; f := t-e; process begin L1: loop c <= '1'; wait for e; c <= '0'; wait for f; end loop; end process; end logical;
The error is { Error (10500): VHDL syntax error at test_language_vhdl.vhd(27) near text ":="; expecting "(", or "'", or "." }
Thanks in advance.
--- Quote Start ---
Hi everyone
Thanks in advance.
--- Quote End ---
declare your variables after process. I am not sure if your code is synthesisable due to wait for.
I declared the variables after "process" and now another error appears, involving the division operator. My new code is:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_signed.all; use ieee.std_logic_unsigned.all; entity pwm_generator is port( a, b: in bit_vector (31 downto 0); c: out bit); end pwm_generator; --The input 'a' means the frequency, of signal pwm, in binary. For example 1234Hz is 00000000000000000000010011010010Hz --The input 'b' means the duty cicle in binary. For example 27% is 00000000000000000000000000011011% --The output 'c' means the output of pwm signal. architecture logical of pwm_generator is begin process variable a1, b1: integer; variable t, e, f, b2: real; --The variable 't' means the period (in seconds) of pwm signal. --The variable 'e' means the time (in seconds) of the high level ('1') of the pwm signal. --The variable 'a1' means the decimal representation of the input 'a'. --The variable 'b1' means the decimal representation of the input 'b'. --The variable 'f' means the time (in seconds) of the low level ('0') of the pwm signal. --The variable 'b2' means the percentage in decimal of 'b1'. begin a1 := to_integer(unsigned(to_stdlogicvector(a))); b1 := to_integer(unsigned(to_stdlogicvector(b))); b2 := b1/100; t := 1/a1; e := t*b2; f := t-e; L1: loop c <= '1'; wait for e; c <= '0'; wait for f; end loop; end process; end logical;
The error is: { Error (10327): VHDL error at teste_linguagem_vhdl.vhd(33): can't determine definition of operator ""/"" -- found 0 possible definitions
About the "wait for" if don't work I'll change my idea.
--- Quote Start ---
--- Quote End ---
just comment out t:1/a1 as it is not doing anything. After all / is not supported for synthesis as far as I know
Frankly I don't understand what you are aiming at.
also avoid mixing of libraries, just use numeric_std instead of signed/unsigned
edit: sorry about t, it is used later but you can't use / for synthesis
I suggest the following:
set your inputs as follows:
a: in std_logic_vector(15 downto 0);
b: in std_logic_vector(7 downto 0);
clkin: in std_logic;
clkout: out std_logic
(a) to be your clkout period in clk samples (not absolute time and not frequency)
(b) is duty cycle but scaled by 128/100(to avoid division)
compute (b1) from (a) & (b) in logic as follows:
in logic multiply (b) by (a) then discard 7 bits b1 = a*b/128 (e.g. for 27% duty cycle b1 = a*35/128)
run a counter on clk starting from zero and increment by 1 till a value equal to (a-1) and back.
finally decide clkout logic: if count = (b1-1) clkout to be high and if count = (a-1) clkout to be low (or the reverse).
