17268 Discussions
-Binary Up/down counter with saturation has no output
About Quartus's template--Binary Up/down counter with saturation.
Why it has no output when count_up=0(down count)?My device is EP2C5AT144A7.
Up counter work‘s ok.
// Quartus II Verilog Template
// Binary up/down counter with saturation
module binary_up_down_counter_with_saturation
# (parameter WIDTH=32)
input clk, enable, count_up, reset,
output reg [WIDTH-1:0] count
reg [WIDTH-1:0] direction;
reg [WIDTH-1:0] limit;
// Reset if needed, increment or decrement if counter is not saturated
always @ (posedge clk or posedge reset)
begin
if (reset)
count <= 0;
else if (enable == 1'b1)
begin
if (count_up)
begin
direction <= 1;
limit <= {WIDTH{1'b1}}; // max value is all 1's
end
else
begin
direction <= -1;
limit <= {WIDTH{1'b0}};
end
if (count != limit)
count <= count + direction;
end
end
endmodule
Unless I'm missing something, when count_up=0, out of reset count=limit=0, so in your last if statement, count will remain the same.
