17256 Discussions
Bugs in Q20.1 Vector Waveform Editor and Modelsim simulation.
BrianHG
I just upgraded from Q18.1 to 20.1.  I found 2 bugs with opening or generating a new .vwf (vector waveform file) and running a functional or timing simulation.
1.  When creating a 'New University Program VWF' and adding the IO pins and clock, If I save as with a file name anything other than 'Waveform.vwf', I get an error message:
Error (199014): Vector source file C:/altera/Qdesigns/HDMI_480p_1KHz_Sine/Waveform1.vwf specified with --testbench_vector_input_file option does not exist
Error: Quartus Prime EDA Netlist Writer was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 495 megabytes
Error: Processing ended: Sat Jan 09 21:00:35 2021
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error.
2.  Now, when I do save the file name as 'Waveform.vwf', I get this new error:
# vsim -novopt -c -t 1ps -L cycloneive_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver work.HDMI_test_vlg_vec_tst
# Start time: 21:03:23 on Jan 09,2021
# ** Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
# Error loading design
# End time: 21:03:23 on Jan 09,2021, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
This used to work fine in Quartus Prime Lite 18.1.
Other than downgrading, is there a fix?
SyafieqS
Hi Brian,
Remove the novopt command in your script and resimulate.
BrianHG
Ok, found a solution.  I just need to remove the -novopt option every time in the simulator setting as Quartus keeps on inserting it in new projects.
SyafieqS
Hi Brian,
