Error (12252)
AK40
Hi
I get errors when I compiling my old PC archive Quartus project on my new PC, where this archive is compiling correctly on other PCs.
The new PC have the below HW & SW:
Windows10
Processor: Intel core i7-9700 cpu@3GHz
Installed memory (RAM): 16 GB
System type: 64bit
QUARTUS18.1  BUILD 625 STANDARD EDITION
When I compile the project I get the below error:
Error (12252): REMOTE_UPDATE: Failed to generate module ep_g1x1_REMOTE_UPDATE
Error (12252): Generation stopped, 74 or more modules remaining
Error (12153): Can't elaborate top-level user hierarchy
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 33 warnings
                Error: Peak virtual memory: 5009 megabytes
                Error: Processing ended: Mon Jan 04 11:13:02 2021
                Error: Elapsed time: 00:01:42
                Error: Total CPU time (on all processors): 00:02:35
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 33 warnings
Please advise what shall I do?
Thank in advance,
sstrell
Did you move to a newer version of Quartus?  A generation error means that the tool is unable to generate the HDL files for the IP indicated which could happen because of changes in the IP between versions of the software.  If not, try going to the parameter editor for the IP listed and manually regenerate the IP yourself before trying to recompile the whole design.
KhaiChein_Y_Intel
Have you tried sstrell's suggestion?
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
