17268 Discussions
Building the Host Program using "make"
Hi Guys,
I am working on Hello world program.
I am trying to compile make file. I got below error:
ravi@kt-warp16 ~/Desktop/Screensho/HelloWorld/hello_world
$ make
arm-linux-gnueabihf-g++ -Ihost/inc -I../common/inc
-IC:/altera/14.0/hld/host/include ../common/src/AOCL_Ut
ils.cpp host/src/main.cpp -LC:\altera\14.0\hld\board\arrow_c5sockit_bsp\arm32\li
b -LC:/altera/14.0/hld/host/arm32/lib -lalteracl -lalterahalmmd -lalterammdpcie
-lelf -lrt -lstdc++
-L../common/lib
-o bin/hello_world
process_begin: CreateProcess(NULL, arm-linux-gnueabihf-g++ -Ihost/inc -I../commo
n/inc -IC:/altera/14.0/hld/host/include ../common/src/AOCL_Utils.cpp host/src/ma
in.cpp -LC:\altera\14.0\hld\board\arrow_c5sockit_bsp\arm32\lib -LC:/altera/14.0/
hld/host/arm32/lib -lalteracl -lalterahalmmd -lalterammdpcie -lelf -lrt -lstdc++
-L../common/lib -o bin/hello_world, ...) failed.
make (e=2): The system can not find the file specified
make: *** [bin/hello_world] Error 2
Because of this erroe I am not able to generate /hello_world file under bin folder.
Could you please help me to solve this 2 error. I am quite new in OpenCL. any type of help would be appreciated. Thanks in advance.
--- Quote Start ---
Hi Guys,
$ make
-lelf -lrt -lstdc++
-L../common/lib
-o bin/hello_world
--- Quote End ---
It would be appreciatted, if someone can answer of my problem.
Make says it all; it can't find some of the specified files in the command. Just verify Make sure the paths to all your source files and indicated libraries are correct.
