17268 Discussions
Quartus II Internal Error
I'm not very experienced with FPGAs. Can some one help me with the following problem please!
I did "Analysis an Elaboration" on my design and it was successful.
Then I tried "Analysis and Synthesis" and I get the following error. I guess it is related to timing and .sdc file.
Can someone give me a clue how to resolve this problem?
Internal Error: Sub-system: SSC, File: /quartus/tsm/ssc/ssc_timing.cpp, Line: 93 !use_relaxed_slacks || (tdc_edge_slacks != 0)
Stack Trace:
0xf460: SSC_UTIL::compute_average_lut_delay + 0xed0
0x10b77: SSC_UTIL::perform_timing_analysis + 0x467
0x342ce: sutil_ssc_perform_timing_analysis + 0x1be
0x68b6f: MAP_TESLA::set_lut_cost + 0x400f
0x670e0: MAP_TESLA::set_lut_cost + 0x2580
0x26d7e: FTM_ROOT_IMPL::lutmap + 0x54e
0x24392: FTM_ROOT_IMPL::start_normal_flow + 0x152
0x23909: FTM_ROOT_IMPL::start + 0x149
0x23008: FTM_ROOT::start + 0x128
0x604a3: scl_start + 0x5ab83
0x6101d: scl_start + 0x5b6fd
0x65113: scl_start + 0x5f7f3
0x2ebb5: scl_start + 0x29295
0x2f7b7: scl_start + 0x29e97
0x2fcff: scl_start + 0x2a3df
0x5435: scl_run_parallel_mls_script + 0xf95
0x11fad: qexe_get_command_line + 0x1b7d
0x14e0e: qexe_process_cmdline_arguments + 0x59e
0x14f21: qexe_standard_main + 0xa1
0x4ae8: msg_exe_fini + 0x58
0x522c: msg_exe_fini + 0x79c
0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5e0f: msg_exe_main + 0x8f
0x159bc: BaseThreadInitThunk + 0xc
0x2a2e0: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.0 Build 156 04/24/2013 SJ Web Edition
This is a crash - no idea what caused it. Try a newer version of quartus or raising a support ticket.
--- Quote Start ---
--- Quote End ---
Thank you. I did file a service request.
But I guess it has something to do with the timing. As I was trying to do analysis and elaboration, I was getting error for my verilog.v file. Finally I resolved that problem and now I'm getting this problem. I have minimum experience with creating .sdc file.
It could be anything - wait and see what altera suggest. Have you tried in a different version?
