17261 Discussions
Calculating no. of transitions
How can i identify the no. of transition (0->1 or 1->0) in a sequence and the number of non transitions in that sequence(1->1 or 0->0).....
for example.....
consider a 8 bit sequence 01101001
no. of transitions 5
no. of non transitions 2
anyone know to solve this in vhdl.....pls help me
what have you got so far and where are you stuck?
One way to do it would be to XOR each bit with its neighbor on the right, append some zeros on the left to each result (in the example case 2 zeros would be sufficient since you are never going to have more than 7) then add them all up. This will give you the number of transitions. Subtract this from the total# bit -1 and you have the number of non-transitions. If it isn't very many bits and it is the same number of bits every time then this should work.
How many bits are we talking about here?
