Is it possible to highlight several separate entities in the floorplanner, preferably giving each entity a different colour?
Currently Im just using the project navigator -> rightclick -> locate in floorplanner. So it saves the different searches, but Id like to show several at once.Link Copied
What version of Quartus? I think for a year or two you've been able to select multiple hierarchies, and they come up in different colors. In 12.1 there's a report window showing each hierarchy and it's color, and you can check/uncheck them. (It only shows the hierarchies you've located...)
That sounds great. Unfortunatly Im lumbered with 10.1 for this project
https://www.alteraforum.com/forum/attachment.php?attachmentid=7061 Yep, I think it was added shortly after. (It was "beta" for a few releases, but worked fine). Not to rub it in, but I added a sceenshot...:D
Grr - that would be good.
There is talk around the office it has been done with this version before, only with tcl commands. Any ideas?
