17254 Discussions
Can not create the jam file
In order to do In System Programming for the Stratix4GX530's flash devices, I need to create the .jam file from .pof file. I am using File --> Create JAM SVF ISC ... option in the Quartus II programmer GUI. But when I do that, I am getting following error
Can't create JAM, SVF or ISC file because EP4SGX530/ES cannot be determined
Do you happen to know the reason why I may be getting this error?
By the way I am using following appnote to support ISP in our project. Page 14-6 describes how to create the jam file.
http://www.altera.com/literature/hb/max2/max2_mii51015.pdf (https://myemail.amd.com/owa/redir.aspx?c=762db23f71d144c6aa8263b50a0c3b89&url=http%3a%2f%2fwww.altera.com%2fliterature%2fhb%2fmax2%2fmax2_mii51015.pdf
