17267 Discusiones
Can not edit component in Quartus 7.2 sp1
Colaborador Distinguido II
1.846 Vistas
When i build a SOPC in Quartus 7.2 sp1, it seems more difficult and more problem when i do that in Quartus 6.0:
1. When i adds many verilog files to create a component, SOPC builder automatically choose the top module file for the component and i cant choose another of them for top module.
2. About the setting for signal of the component, sometimes i can not set my signals as export or clk or reset because the list of "Signal Type" do not contain such types.
3. ...
Does anyone experience with this version of Quartus please help me? :(
Thanks alot!
0 kudos
4 Respuestas
1.028 Vistas
Hi Leven:
"1. When i adds many verilog files to create a component, SOPC builder automatically choose the top module file for the component and i cant choose another of them for top module."
Yes I've seen this. The first file you add, must contain the top file. Then add the remaining files. I agree this should be fixed.
"2. About the setting for signal of the component, sometimes i can not set my signals as export or clk or reset because the list of "Signal Type" do not contain such types."
They have now added may new types of interfaces to SOPC. Clocks and resets are now under a "Clock Input" type, and Exports are available under the "Conduit Output" and "Conduit Input"
The nice thing, is is you have multiple clocks and resets, you can now define what clock domain what interface is in, and hook it up appropriately in SOPC, with out exporting the extra clocks to the top to figure it out.
Pete
1.028 Vistas
@Pete: thanks for your helping,i will try it...
1.028 Vistas
what difference between "Conduit Output" and "Conduit Input"??
1.028 Vistas
It depends if your conduit ine is attached to an output pin or to an input pin.
Responder
