17255 讨论
Can't Simulate Buffer port in ModelSim
名誉分销商 II
1,724 次查看
Hello everyone, I have the following simple VHDL code for clock frequency division:
---------------------- Frequency division using Variables -------------------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY freq_divider IS
PORT ( clk : IN STD_LOGIC;
out2 : BUFFER STD_LOGIC);
END freq_divider;
ARCHITECTURE example OF freq_divider IS
BEGIN
PROCESS (clk)
VARIABLE count2 : INTEGER RANGE 0 TO 7;
BEGIN
IF (clk'EVENT AND clk='0') THEN
count2 := count2 + 1;
IF (count2 = 3) THEN
out2 <= NOT out2;
count2 := 0;
END IF;
END IF;
END PROCESS;
END example;
But when I try to Simulate it with modelsim-altera the (out2) signal does not give me any value. I was wondering is it because the port is assigned as (buffer)????? Please help me. Thanks
0 项奖励
2 回复数
名誉分销商 II
943 次查看
Did you provide a clock on the clock port?
0 项奖励
名誉分销商 II
943 次查看
with "does not give any value" I assume you mean 'U'? If so, it's because you never initialize "out2" to any value.
Also, I agree with Tricky, you need a testbench that provides a clock. If you don't know about testbenches, Google has plenty of examples, e.g. here: https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/ (https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/).
GooGooCluster
0 项奖励
回复
