17255 讨论
The Value of tx_pll_m_divider is invalid
名誉分销商 II
1,208 次查看
Hi Everyone;
I am trying to synthesise Altera's 10GBASE-R PHY IP but I get these three errors
Error (272006): The chosen data rate or input clock frequency cannot be implemented. (The value of tx_pll_m_divider is invalid)
Error (272006): The chosen data rate or input clock frequency cannot be implemented. (The value of rx_cru_m_divider is invalid)
Error (287078): Assertion error: Valid clear box generator not found or Errors encountered during clear box generation
Assuming that fixing the first two errors fixes the third as well, I did some research but couldn't resolve it. Altera's support website says you have to use the MegaWizard plug-in to generate the instantiation but it doesn't give any instantiation template. It generates a component declaration file which I am using for declaring the component. Been trying to go round this problem for some days now so any help will be highly appreciated.
0 项奖励
0 回复数
回复
