17261 Discussions
Programming MAX 10 with .mif
I'm trying to program a 10M50 on the Altera Development Kit. It's programming fine, but I'm not getting the expected readout over UART (I keep getting a semi-random single number continously), so I'd like to confirm that I'm filling the RAM correctly. The RAM is a 2-port altsyncram from the IP generator, and simulates correctly.
Can anyone see if I'm doing it right?
https://s30.postimg.org/4rk3103vh/programmer.png (https://postimg.org/image/4rk3103vh/
The .mif file:
DEPTH = 12500; -- The size of memory in words WIDTH = 12; -- The size of data in bits ADDRESS_RADIX = HEX; -- The radix for address values DATA_RADIX = HEX; -- The radix for data values CONTENT -- start of (address : data pairs) BEGIN -- memory address : data -- 1..12500 0000 : 0001; 0001 : 0002; 0002 : 0003; 0003 : 0004; 0004 : 0005; 0005 : 0006; 0006 : 0007; 0007 : 0008;
And it goes on like that up to 12499.
The .qsf file contains:
set_global_assignment -name MIF_FILE ../source/RAM_init.mif
And in Quartus, this option is selected:
Assignments -> Device -> Device and Pin Options -> Configuration -> Configuration Mode: Single Uncompressed Image with Memory Initialization (512Kbits UFM)
The RAM:
LIBRARY ieee;USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.altera_mf_components.all; ENTITY RAM IS PORT ( data : IN STD_LOGIC_VECTOR (11 DOWNTO 0); rdaddress : IN STD_LOGIC_VECTOR (13 DOWNTO 0); rdclock : IN STD_LOGIC ; rden : IN STD_LOGIC := '1'; wraddress : IN STD_LOGIC_VECTOR (13 DOWNTO 0); wrclock : IN STD_LOGIC := '1'; wren : IN STD_LOGIC := '0'; q : OUT STD_LOGIC_VECTOR (11 DOWNTO 0) ); END RAM; ARCHITECTURE SYN OF ram IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (11 DOWNTO 0); BEGIN q <= sub_wire0(11 DOWNTO 0); altsyncram_component : altsyncram GENERIC MAP ( address_aclr_b => "NONE", address_reg_b => "CLOCK1", clock_enable_input_a => "BYPASS", clock_enable_input_b => "BYPASS", clock_enable_output_b => "BYPASS", init_file => "../source/RAM_init.mif", intended_device_family => "MAX 10", lpm_type => "altsyncram", numwords_a => 12500, numwords_b => 12500, operation_mode => "DUAL_PORT", outdata_aclr_b => "NONE", outdata_reg_b => "CLOCK1", power_up_uninitialized => "FALSE", rdcontrol_reg_b => "CLOCK1", widthad_a => 14, widthad_b => 14, width_a => 12, width_b => 12, width_byteena_a => 1 ) PORT MAP ( address_a => wraddress, address_b => rdaddress, clock0 => wrclock, clock1 => rdclock, data_a => data, rden_b => rden, wren_a => wren, q_b => sub_wire0 ); END SYN;
/edit: I tried the In-System Memory Content Editor, but it does not detect the RAM, which I'm thinking is a clue.
https://s29.postimg.org/4e30d5lgz/memory_editor.png (https://postimg.org/image/4e30d5lgz/)
Yes, that's a clue. RAM looks OK. Post the code where you've instantiated it.
Cheers,
Alex
Alex,
The RAM is instantiated in ADC_RAM which in turn is instantiated in UTTM.
library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_std.all; entity ADC_RAM is port ( clock : in std_logic; -- input from higher level async_reset : in std_logic; -- input from higher level ADC_inclock : in std_logic; -- input from pin ADC_in : in std_logic_vector (5 downto 0); -- input from pin ADC_oe : out std_logic; -- output to pin ADC_SCL : out std_logic; -- output to pin ADC_SDA : inout std_logic; -- bidirecional to pin ADC_SENn : out std_logic; -- output to pin ADC_OVR : in std_logic; -- input from pin rdaddress : in std_logic_vector (13 downto 0); -- input from higher level rden : in std_logic := '1'; -- input from higher level q : out std_logic_vector (11 downto 0); -- output to higher level activation : in std_logic; -- input from higher level completion : out std_logic); -- output to higher level end entity ADC_RAM; architecture RTL of ADC_RAM is -- RAM component RAM port ( data : in std_logic_vector (11 downto 0); rd_aclr : in std_logic := '0'; rdaddress : in std_logic_vector (13 downto 0); rdclock : in std_logic ; rden : in std_logic := '1'; wraddress : in std_logic_vector (13 downto 0); wrclock : in std_logic := '1'; wren : in std_logic := '0'; q : out std_logic_vector (11 downto 0) ); end component RAM; -- FSM type statetype is (S0, S1, S2, S3, S4); signal state, nextstate : statetype; -- Misc Clock domain: signal clock_Core : std_logic; -- Core signal clock_ADC : std_logic; -- ADC signal clock_ADC_config : std_logic; -- ADC signal reset_Core : std_logic; -- Core signal reset_ADC : std_logic; -- ADC signal RAM_filled_ADC : std_logic; -- ADC signal LVDStoRAM_en_ADC : std_logic; -- ADC signal RAM_filled_Core : std_logic; -- Core signal LVDStoRAM_en_Core : std_logic; -- Core signal ADC_wait_start : std_logic; -- ADC signal ADC_wait_done : std_logic; -- ADC signal ADC_config_start_Core : std_logic; -- Core signal ADC_config_start_ADC : std_logic; -- ADC signal ADC_config_done_Core : std_logic; -- Core signal ADC_config_done_ADC : std_logic; -- ADC -- RAM signal data_sig : std_logic_vector (11 downto 0); -- signal rdaddress_sig : std_logic_vector (13 downto 0); -- signal rdclock_sig : std_logic; -- signal rden_sig : std_logic; signal wraddress_sig : std_logic_vector (13 downto 0); -- signal wrclock_sig : std_logic; signal wren_sig : std_logic; -- signal q_sig : std_logic_vector (11 downto 0) begin -- RAM RAM_inst : RAM port map ( data => data_sig, -- internal rd_aclr => reset_Core, -- port through async_reset_sync_release process rdaddress => rdaddress, -- port rdclock => clock_Core, -- port through signal rden => rden, -- port wraddress => wraddress_sig, -- internal wrclock => clock_ADC, -- port through signal wren => wren_sig, -- internal q => q -- port );
library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_std.all; entity UTTM is port ( CPU_RESETn : in std_logic; -- 3.3V LVCMOS CLK_50_MAX10 : in std_logic; -- 2.5V CLK_25_MAX10 : in std_logic; -- 2.5V CLK_LVDS_125_p : in std_logic; -- 2.5V CLK_10_ADC : in std_logic; -- 2.5V HSMC_CLK_IN_p : in std_logic; -- LVDS (CLKOUTM) / PINS: V10, V9 HSMC_RX_D_p : in std_logic_vector(5 downto 0); -- LVDS / PINS: AB7, Y4, AB5, W13, AB15, Y16, AB6, Y3, AA5, W12, AA14, AA15 HSMC_SCL : out std_logic; -- 2.5V / PIN: Y18 HSMC_SDA : inout std_logic; -- 2.5V / PIN: AA19 HSMC_SENn : out std_logic := '0'; -- 2.5V / PIN: Y7 HSMC_OVR : in std_logic; -- 2.5V / PIN: Y8 ); end entity UTTM; architecture RTL of UTTM is component ADC_RAM port ( clock : in std_logic; async_reset : in std_logic; ADC_inclock : in std_logic; ADC_in : in std_logic_vector(5 downto 0); ADC_oe : out std_logic; ADC_SCL : out std_logic; ADC_SDA : inout std_logic; ADC_SENn : out std_logic; ADC_OVR : in std_logic; rdaddress : in std_logic_vector(13 downto 0); rden : in std_logic; q : out std_logic_vector(11 downto 0); activation : in std_logic; completion : out std_logic ); end component; -- FSM type statetype is (S0, S1, S2, S3); signal state, nextstate : statetype; signal statecode : std_logic_vector(7 downto 0) := (others => '0'); -- ADC/RAM signal RAM_address : std_logic_vector(13 downto 0) := (others => '0'); -- output signal RAM_read_en : std_logic := '0'; -- output signal RAM_dataout : std_logic_vector(11 downto 0); -- input signal ADC_activation : std_logic := '0'; -- output signal ADC_completion : std_logic; -- input --constant ADC_wait_cycles : natural := 13; -- "wait for valid ADC data" delay = 100 ns begin ADC_RAM_instance : ADC_RAM port map ( clock => CLK_LVDS_125_p, async_reset => not CPU_RESETn, ADC_inclock => HSMC_CLK_IN_p, ADC_in => HSMC_RX_D_p, ADC_oe => open, ADC_SCL => HSMC_SCL, ADC_SDA => HSMC_SDA, ADC_SENn => HSMC_SENn, ADC_OVR => HSMC_OVR, rdaddress => RAM_address, rden => RAM_read_en, q => RAM_dataout, activation => ADC_activation, completion => ADC_completion );
/edit: Added the "rd_aclr" to the RAM compared to the top post to see if that fixed anything, but there was no difference.
LIBRARY ieee;USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.altera_mf_components.all; ENTITY RAM IS PORT ( data : IN STD_LOGIC_VECTOR (11 DOWNTO 0); rd_aclr : IN STD_LOGIC := '0'; rdaddress : IN STD_LOGIC_VECTOR (13 DOWNTO 0); rdclock : IN STD_LOGIC ; rden : IN STD_LOGIC := '1'; wraddress : IN STD_LOGIC_VECTOR (13 DOWNTO 0); wrclock : IN STD_LOGIC := '1'; wren : IN STD_LOGIC := '0'; q : OUT STD_LOGIC_VECTOR (11 DOWNTO 0) ); END RAM; ARCHITECTURE SYN OF ram IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (11 DOWNTO 0); BEGIN q <= sub_wire0(11 DOWNTO 0); altsyncram_component : altsyncram GENERIC MAP ( address_aclr_b => "CLEAR1", address_reg_b => "CLOCK1", clock_enable_input_a => "BYPASS", clock_enable_input_b => "BYPASS", clock_enable_output_b => "BYPASS", init_file => "../../source/RAM_init.mif", intended_device_family => "MAX 10", lpm_type => "altsyncram", numwords_a => 12500, numwords_b => 12500, operation_mode => "DUAL_PORT", outdata_aclr_b => "CLEAR1", outdata_reg_b => "CLOCK1", power_up_uninitialized => "FALSE", ram_block_type => "M9K", rdcontrol_reg_b => "CLOCK1", widthad_a => 14, widthad_b => 14, width_a => 12, width_b => 12, width_byteena_a => 1 ) PORT MAP ( aclr1 => rd_aclr, address_a => wraddress, address_b => rdaddress, clock0 => wrclock, clock1 => rdclock, data_a => data, rden_b => rden, wren_a => wren, q_b => sub_wire0 );
--- Quote Start ---
--- Quote End ---
It hardly can unless "ENABLE_RUNTIME_MOD=YES" is set for the RAM instance. And it can't work for dual-port RAM because one port is needed for the JTAG interface.
I don't see ENABLE_RUNTIME_MOD in the RAM HDL, so what should I map to in the RAM instance?
I could make a quick single-port just to check.
Is there another way I can check the (dual-port) RAM functionality?
As I mentioned I already simulated it successfully, writing it full it then reading it.
I simplified the RTL considerably, and now it's just outputting zeroes over UART :confused:
library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_std.all; entity UTTM is port ( CPU_RESETn : in std_logic; -- 3.3V LVCMOS CLK_50_MAX10 : in std_logic; -- 2.5V CLK_25_MAX10 : in std_logic; -- 2.5V CLK_LVDS_125_p : in std_logic; -- 2.5V CLK_10_ADC : in std_logic; -- 2.5V USER_LED : out std_logic_vector(4 downto 0); -- 1.5V USER_PB : in std_logic_vector(3 downto 0); -- 1.5V USER_DIPSW : in std_logic_vector(4 downto 0); -- 1.5V UART_TX : out std_logic -- 2.5V ); end entity UTTM; architecture RTL of UTTM is -- UART component uart_simple port ( i_clk : in std_logic; I_clk_baud_count : in std_logic_vector(15 downto 0); i_reset : in std_logic; i_txdata : in std_logic_vector(7 downto 0); i_txsig : in std_logic; o_txrdy : out std_logic; o_tx : out std_logic ); end component; -- RAM component RAM port ( data : in std_logic_vector (11 downto 0); rd_aclr : in std_logic := '0'; rdaddress : in std_logic_vector (13 downto 0); rdclock : in std_logic ; rden : in std_logic := '1'; wraddress : in std_logic_vector (13 downto 0); wrclock : in std_logic := '1'; wren : in std_logic := '0'; q : out std_logic_vector (11 downto 0) ); end component RAM; -- FSM type statetype is (S0, S1, S2); signal state, nextstate : statetype; signal statecode : std_logic_vector(7 downto 0) := (others => '0'); -- UART signal txdata : std_logic_vector(7 downto 0) := (others => '0'); signal txsig : std_logic := '0'; signal txrdy : std_logic := '0'; signal rdaddress : std_logic_vector (13 downto 0); signal rden : std_logic; signal q : std_logic_vector (11 downto 0); signal TX_activation : std_logic := '0'; signal TX_completion : std_logic := '0'; begin uart_instance : uart_simple port map ( I_clk => CLK_LVDS_125_p, I_clk_baud_count => X"32DD", -- 9600 bps @ 125 MHz clock --I_clk_baud_count => X"043D", -- 115200 bps @ 125 MHz clock --I_clk_baud_count => X"0088", -- 921600 bps @ 125 MHz clock I_reset => not CPU_RESETn, I_txdata => txdata, i_txsig => txsig, o_txrdy => txrdy, O_tx => UART_TX ); -- RAM RAM_inst : RAM port map ( data => (others => '0'), rd_aclr => not CPU_RESETn, rdaddress => rdaddress, rdclock => CLK_LVDS_125_p, rden => rden, wraddress => (others => '0'), wrclock => '0', wren => '0', q => q ); -- may need to add a first-run variable as RAM has not yet been read out for first UART transmission tx_RAM_process : process (CLK_LVDS_125_p, CPU_RESETn) variable i : integer := 0; begin if CPU_RESETn = '0' then i := 0; txdata <= (others => '0'); txsig <= '0'; rden <= '0'; rdaddress <= (others => '0'); TX_completion <= '0'; elsif rising_edge(CLK_LVDS_125_p) then if txrdy = '1' and TX_activation = '1' then if i <= (12500-1) then -- output loop begin i := i + 1; txdata <= q(11 downto 4); txsig <= '1'; rden <= '1'; rdaddress <= std_logic_vector(to_unsigned(i,14)); TX_completion <= '0'; else i := 0; txdata <= (others => '0'); txsig <= '0'; rden <= '0'; rdaddress <= (others => '0'); TX_completion <= '1'; end if; -- output loop end end if; end if; end process; FSM_clock_process : process (CLK_LVDS_125_p, CPU_RESETn) is begin if rising_edge(CLK_LVDS_125_p) then if CPU_RESETn = '0' then state <= S0; else state <= nextstate; end if; end if; end process FSM_clock_process; FSM_io_process : process (CPU_RESETn, state, TX_completion, USER_PB) is begin if CPU_RESETn = '0' then TX_activation <= '0'; nextstate <= S0; USER_LED(3 downto 0) <= "1111"; else -- default assignments TX_activation <= '0'; nextstate <= state; USER_LED(3 downto 0) <= "1111"; case state is -- idle state after reset when S0 => USER_LED(3 downto 0) <= "1110"; if USER_PB = "1110" then TX_activation <= '1'; nextstate <= S1; end if; when S1 => USER_LED(3 downto 0) <= "1100"; if TX_completion = '1' then TX_activation <= '0'; nextstate <= S2; end if; when S2 => USER_LED(3 downto 0) <= "1000"; if USER_PB = "0111" then nextstate <= S0; end if; end case; end if; end process FSM_io_process; end architecture RTL;
