My project name is CPLD.qpf (MAX II). I created a .vwf file (OneShot.vwf) which should test a section of CPLD. There is a file named OneShot.bdf (it is part of the CPLD project) and I would like to test it. Under "Setting/Timing Analysis Setting" I selected the Use Classic option. Under "Setting/Simulator Setting" I chose Functional as my Simulator mode, and set OneShot.wvf as my Simulation input. I am trying to run the simulator on OneShot.vwf by clicking the "Start Simulator" button. The "Simulation Waveforms" shown is for the whole project (CPLD) and not for OneShot.vwf. What am I doing wrong here? Thanks, Eitan Barazani連結已複製
6 回應
I don't understand the question. I suggested to set the OneShot entity as design top for test. Then it's ports aren't internal.
I suggested to simulate the component alone, because you complained about seeing the waveform for the whole project.--- Quote Start --- but I am trying to find out if this the only way? --- Quote End --- It depends on the purpose of your simulation. But I think, in most cases it means faster simulation and direct access to all nodes of interest. If you need part of the embedding design to stimulate your component in a specific way, it's different.
