17268 Discussions
Debugging using the Quartus simulator?
I have designed a simple block to be programmed onto FPGA.
Currently there is a bug which I am trying to find - I am using the quartus simulator and would like to know if annybody knows how to setup the simulator so that I can view internal signal values after the simulation has completed. Can find in manual.
So far I can only get it to report the values of the top level pins which is not helping me.
Thanks in advance!
--- Quote Start ---
Thanks in advance!
--- Quote End ---
you have to define the signals in your <>.vwf.
Open the file and:
double-click into the "Name" column
A new window pops-up "Insert Node or Bus"
Click on "Node Finder" and choose your signals
Kind regards
GPK
Hi GPK,
what you descibe is pritty much what I was doing but am getting the following warnings when I start the simulation.
Info: Using vector source file "vhdl/peripherals.vwf"
Warning: Can't find node "tst_peripherals_trans:uut|counter[3]" for functional simulation. Ignored vector source file node.
this internal node is a register so bit surpried that it cannot be found - any ideas?
thanks,
John.
--- Quote Start ---
Hi GPK,
thanks,
John.
--- Quote End ---
Hi John,
did you choose "post-synthesis" Nodes ?
Kind regards
GPK
Hi GPK,
I choose pre synthesis nodes as I had not yet gone through the synthesis flow as want to verify my design first. Is this wrong?
John.
--- Quote Start ---
Hi GPK,
John.
--- Quote End ---
Hi John,
it seems that some optimizations takes place by generating the functional netlist. Your warning indicates that the counter bit is obsolet in your design. It is at least a misleading behaviour of the simulator.
Kind regards
GPK
