17268 Discussions
Interfacing with I2C (EEPROM) chip.
Dear all,
I am using Altera Stratix II board.I need to implement I2C interface.
I have connected the I2C (AT24C04 EEPROM) to the board using 2 pins namly sda and scl.
Now My Problem is :
say for write operation ,I need to send device address , word address and data , three things.
I am showing the code below for that.
input clk_50;
inout scl ;
inout sda ;
output int_ack_device ,int_ack_word ,int_ack_data;
reg int_ack_device ,int_ack_word ,int_ack_data,exit_flag;
reg [7:0] clk_count ; //used to generate i2c clock scl
reg out_scl_s1,out_scl_s2,out_scl_s3,out_scl_s4;
reg [7:0] device_address ;
reg [7:0] word_address ;
reg [7:0] data ;
reg [5:0] state ;//making state = 1 to enter into the state machine .
reg out_sda ;
OPNDRN SDA1 (.in(out_sda ), .out(sda));
assign scl = out_scl_s4 ;
//module to derive out_scl_s4 from clk_50.
always @( out_scl_s4)
begin
if ((exit_flag == 0))
begin
case(state)
6'b000001: //generating start condition. state 1
begin
# 7500 out_sda <= 1'b0 ;
state <= 6'b000010 ;
end
6'b000010: //putting device address on bus
begin
out_sda <= device_address[7]; //1
state <= 6'b000011;
end
6'b000011:
begin
out_sda <= device_address[6]; //0
state <= 6'b000100;
end
6'b000100:
begin
out_sda <= device_address[5]; //1
state <= 6'b000101;
end
6'b000101:
begin
out_sda <= device_address[4]; //0
state <= 6'b000110;
end
6'b000110:
begin
out_sda <= device_address[3]; //0
state <= 6'b000111;
end
6'b000111:
begin
out_sda <= device_address[2]; //0
state <= 6'b001000;
end
6'b001000:
begin
out_sda <= device_address[1]; //0
state <= 6'b001001;
end
6'b001001: // putting read/write (R/!W) bit on sda
begin
out_sda <= device_address[0]; //0 w
state <= 6'b001010 ;
end
6'b001010: // value on out_sda should come from i2c device.
begin
int_ack_device <= out_sda ; //0
state <= 6'b001011 ;
end
6'b001011:
begin
out_sda <= word_address[7]; // 1 //this bit is set to one.
state <= 6'b001100 ;
end
First ack which i am receiving in int_ack_device is proper.My problem is that when in state 6'b001011: I apply 1 to out_sda.it doesnt go high at all .I am using signaltap tool for seeing the signal.
I think problem lies in holding scl line by slave.
Relevant warnings are :
Warning: Following 4 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
Info: Pin int_ack_device has GND driving its datain port
Info: Pin int_ack_word has GND driving its datain port
Info: Pin int_ack_data has GND driving its datain port
Info: Pin sda has GND driving its datain port /* how to remove this warning ??? */
I am seeking for help in this regard.please help.
-Thanks & Regards
Tushar
opencores and niosforum have i2c cores usable with sopc builder.
