17268 Discussions
Can't locate Getopt/Long.pm when generating a Qsys Project
PGötz
Quartus 19.1 has issues with its perl distribution on Linux. When generating a Qsys project, I get the following error:
Can't locate Getopt/Long.pm in @INC (you may need to install the Getopt::Long module) (
  @INC contains:
     /opt/altera/19.1/quartus/sopc_builder/bin/europa
     /opt/altera/19.1/quartus/../ip/altera/sopc_builder_ip/common
     /opt/altera/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio
     /tools/perl/5.28.1/linux64/lib/site_perl/5.28.1/x86_64-linux
     /tools/perl/5.28.1/linux64/lib/5.28.1/x86_64-linux
  ) at /opt/altera/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio/generate_rtl.pl line 18.
It seems like the perl distribution points to the wrong directory because the library is located at `/opt/altera/19.1/quartus/linux64/perl/lib/5.28.1/Getopt/Long.pm`
I've found a bunch references in the perl distribution pointing to the wrong directory ( https://pastebin.com/wfUKcSjq )
A "fix" seems to be to link to the system perl executeable: http://www.armadeus.org/wiki/index.php?title=Quartus_installation_on_Linux#Perl_Getopt::Long
Full log: https://pastebin.com/b91vNq3k
Linux Distribution: Arch
$ quartus --version
Quartus Prime Design Software
Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition
$ which quartus
/opt/altera/19.1/quartus/bin/quartus
RichardTanSY_Altera
I found a forum case that has a similar issue with yours. Perhaps the solution could help in your current case.
https://forums.intel.com/s/question/0D50P00004VQsDh/does-platform-designer-work-on-ubuntu-1804
PGötz
RichardTanSY_Altera
Hi Paul,
Do you able to solve the issue?
PGötz
I'm able to use Quartus by using the "fix" I mentioned above. Perl in the Quartus installation is still not working out of the box and requires manual changes
SSchu40
For me inserting the line
export PERL5LIB=/opt/intel_fpga/quartus/linux64/perl/lib/5.28.1
into
~/.bashrc
solved the problem. Please note that the application must be restarted to inherit the environment variable.
PGötz
Yeah, but this wasn't necessary with previous versions of Quartus and it could cause further problems or compatibility issues with my systems perl installation.
I have already another "fix" in use (as mentioned above), but would prefer if Intel would recognize this bug and fix it in the next build/release
RichardTanSY_Altera
Fyi, this bug will fix in future releases. In the meanwhile, please use the "fix" that you mentioned above.
