Can't make 'Altera PLL'
cwonb
I want to make Altera PLL by MegaWizard. But the Finish button is disabled.
Here's the error message:
Error: altera_pll: Could not create a temporary work directory
Error: altera_pll: Please make sure that one of TMP, TEMP or HOME environment variables is set and that the directory is writable
It was run as an administrator, but same situation..
I use Quartus II 15.0 and Cyclone V(De1-Soc)
module simple_counter ( CLOCK_50, counter_out ); input CLOCK_50; output reg [31:0] counter_out;   always @ (posedge CLOCK_50) begin counter_out <= #1 counter_out+1; // increase counter end   endmodule
Yonxiad
  • Have you solved it now? I have the same problem
