17268 Discussions
Downloading images through System Console
I am working with the Arria 10 GX eval board and have created a dashboard in System Console to allow me to control my design. My dashboard has a combo box to allow me to select from a list of sof files and a button to allow me to download the selected image. The following is the code attached to the button:
proc btnDownloadClick { } {
global dash
global my_device
set filename [file join output_files [dashboard_get_property $dash cboImage selectedItem]]
foreach possible_device [ get_service_paths device ] {
if { [ regexp 10AT115 $possible_device ] } {
set my_device $possible_device
device_download_sof $my_device $filename
When I first open System Console this code works as expected. I can then use System Console to interact with my design. If I then attempt to download a new image, I get the following error message. I have to exit and restart System Console before I can download a new image.
=== error message follows ===
May 09, 2017 10:18:39 AM com.altera.debug.core
SEVERE: device_download_sof: This device does not have a JTAG connection
SEVERE: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
"device_download_sof $my_device $filename"
(procedure "btnDownloadClick" line 13)
invoked from within
"btnDownloadClick"
java.util.concurrent.ExecutionException: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
invoked from within
"btnDownloadClick"
at com.altera.systemconsole.internal.core.SimpleFuture$Sync.innerGet(SimpleFuture.java:208)
at com.altera.systemconsole.internal.core.SimpleFuture.getInternal(SimpleFuture.java:88)
at com.altera.systemconsole.internal.core.SimpleFuture.get(SimpleFuture.java:61)
at com.altera.systemconsole.dashboard.internal.SystemConsoleDashboard$TCLDashboard$1$1.run(SystemConsoleDashboard.java:70)
at com.altera.systemconsole.internal.core.SystemExecutor$2.run(SystemExecutor.java:306)
at com.altera.systemconsole.internal.core.SystemExecutor$4.run(SystemExecutor.java:553)
at com.altera.systemconsole.internal.core.SystemExecutor$ComparableTask.run(SystemExecutor.java:151)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
invoked from within
"btnDownloadClick"
at com.altera.systemconsole.scripting.ScriptEngine$5.run(ScriptEngine.java:589)
at com.altera.tcl.interpreter.NativeTclWrapper.runEvent(NativeTclWrapper.java:341)
at com.altera.tcl.interpreter.NativeTclWrapper.doOneEvent0(Native Method)
at com.altera.tcl.interpreter.NativeTclWrapper.doOneEvent(NativeTclWrapper.java:355)
at com.altera.tcl.interpreter.NativeTCLInterpreter.waitAndDoOneEvent(NativeTCLInterpreter.java:436)
at com.altera.tcl.interpreter.InterpreterInstantiator$1.run(InterpreterInstantiator.java:59)
... 1 more
Bodil
Did you find a solution? I have the exact same issue with my system console.
