17268 Discussions
Signal Tap not available in last device in JTAG chain
IanBanbrook
I have a JTAG chain of 5 Arria 10 devices, the first device has one configuration, the remaining 4 all have the same config file.  All devices are loaded from attached QSPI eeproms.  I have Signal Tap enabled configs loaded in all devices and all devices are operational.  However, when I try to debug devices 2 to 5 using signal device 5 always responds with "Program the device to continue" while the others respond "Ready to acquire"
Are there issues relating to last device in Jtag chain that could affect operation, if not any advice in debugging the issue would be appreciated
YuanLi_S_Intel
Hi Ian,
Can you try to download the SOF into the 2nd - 5th FPGA and see if the signal tap can work on them?
Bruce
YuanLi_S_Intel
Also, may i know which quartus version you are using?
