Can't run ModelSim help
I have Quartus 14.0 (subscription edition) installed on Ubuntu 12.04.
I am unable to run ModelSim. When I try to run "../modelsim_ae/bin/vsim" or "modelsim_ase/bin/vsim" , I get the error "300: exec: ./../linux/vsim: not found".
Does anyone have any suggestions? Thanks
I had the same problem as you. From my understanding modelsim needs some 32-bit libraries to run and you're most likely operating in 64-bit, correct?
Follow the steps in this link:
http://mattaw.blogspot.de/2014/05/making-modelsim-altera-starter-edition.html
Big thanks to this good samaritan for making his blog post!
Hope this helps!
Thanks alot
When I tried "sudo dpkg --add-architecture i386" , it doesn't recognise command "--add-architecture" ?
However, when I installed the libraries that he lists, ModelSim seems to work as it opens fine.
