I'm trying to use SignalTap II in Simulink. When I hit on "Acquire" I get the following error: http://78.46.62.147/SignalTapII_Logic_Analyser_-_Invalid_MEX-File.pngMatlab Error
Invalid MEX-file 'c:\altera\10.1\quartus\dsp_builder\bin\alt_signaltap_run.mexw32': Die angegebene Prozedur wurde nicht gefunden.
I use: Windows XP SP3 Matlab 2010b + Simulink Quartus II v10.1 DSP Builder v10.1 DSP Development Board - EP2C70F672 Can someone give me a hint on that? Thank you for your time, Leo
Still got the same problem.
Is there a way to recompile the "alt_signaltap_run.mex32" file? The file exists at the expected path, but maybe its damaged.- Mark as New
Solved.
I tried to install various versions of Quartus II and Matlab. Now, I found a working combination. Unfortinately, this combination is not listed in the DSP Builder Handbook Volume I. If I use Quartus 9.1 and Matlab R2010a I'm able to use SignalTab II within Simulink.
