Trying to use SystemVerilog Interfaces.
Create main.sv file with test sources content: interface main_bus; wire [15:0] data; wire [15:0] address; logic [ 7:0] slave_instruction; logic slave_request; logic bus_grant; logic bus_request; logic slave_ready; logic data_ready; logic mem_read; logic mem_write; endinterface module processor ( // main_bus interface port main_bus bus, // other ports input logic clock, input logic resetN, ); // ... // module functionality code endmodule so if I try tool File-Create-CreateSymbolFileForCurrentFile then I'l get error: error (10016): can't create symbol/include/instantiation/component file for module "processor" because port "bus" has an unsupported type What I miss? or BDF just doesn't support SystemVerilog Interfaces feature? P.S. sorry for my English.Link Copied
i don't expect you will get away with advanced types like this in a .bdf. there are also limitations with the VHDL types allowed
you can either port signals out in basic types, or use SystemVerilog instead of .bdf- Mark as New
well.. thanks anyway.
so now I can stop looking for answer and rewrite project and use SV text file in TOP of the project instead bdf.- Mark as New
BDF support for HDLs is pretty poor, and because you cannot do RTL simulations its best to avoid them anyway.
I think it's possible to use a struct
or whatever else signals with concatenation at output. like that: struct { logic [7:0] adr; logic [15:0] data; logic rd; logic wr; } bus; wire [25:0] bus_out = {bus.data, bus.adr, bus.rd, bus.wr}; and then use bus_out as module output. am I wrong?
