17268 Discussions
Cannot generating the completed JESD204B Example Design files
Hi all,
I'm new on using Intel JESD204B IP Core and met some problems.
Since it's my first time trying to implementing the JESD204B IP-Core, I directly follow the intel fpga jesd204b design example step-by-step. But I couldn't get the desired output files as the user guide instructs.
**Link of user guide: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-dex-a10-jesd204b.pdf
According to page 4 of user guide, the output file structure should be something like attached pic_1.
When I click the "Generate Example Design" button with preset configuration in IP Parameter Editor Pro, multi errors occurred.
The message said 'Cannot run program "sys-script" (in driver\QII Installed_path\version\ip\a;tera\altera_jesd204b\src\top)'.
Looks like some parts missing in QuartusII tool chain, but I didn't modify anything after installation.
An of course, I've tried to re-install QuartusII Prime Pro (30-Days Trial) with version 16.1/17.0/17.1, none of these works normally as user guide described.
Did I miss any step or there's some other patch/tools I need to install?
Thanks in advance!
