17256 Discussions
Cannot initialize a 2-D array of bytes from file directly (ram_init_file / $readmemh)
Hello forum Members,
I have been experimenting with file-based initialization of Verilog multidimensional arrays.
Until now i succeeded initializing with the help of flat temp. array
reg charMem; reg colMem; reg charMemTmp; reg colMemTmp; initial begin $readmemh("DE0_CV_SCREENCHAR.txt",charMemTmp); $readmemh("DE0_CV_SCREENCOL.txt" ,colMemTmp); $readmemh("DE0_CV_SCREENPAL.txt" ,palMem); end
and
always @(posedge CLOCK_50) begin if (~RESET_N) begin integer row; integer kol; for (row=0;row<25;row++) begin for (kol=0;kol<80;kol++) begin charMem=charMemTmp; colMem=colMemTmp; end end end end
=> This works fine, i use a flat helper array read in the data and copy everything to a 2-d array.
However if i try to read it directly:
reg charMem; reg colMem; initial begin $readmemh("DE0_CV_SCREENCHAR.txt",charMem); $readmemh("DE0_CV_SCREENCOL.txt" ,colMem); $readmemh("DE0_CV_SCREENPAL.txt" ,palMem); end => I get: "10853 verilog HDL error ... : argument 1 to $readmemh must be a memory identifier ???
I also tried reading from a .mif file (1d file 2000 x 1 byte Width=8 depth=2000):
(* ram_init_file = "DE0_CV_SCREENCHARMEM.mif" *) reg charMem; (* ram_init_file = "DE0_CV_SCREENCOLORMEM.mif" *) reg colorMem
=> this works fine
Does anybody know how to initialize the 2-d array from a file using ram_init_file or $readmemh ?
I a using Quartus 15.1 on Win7.
Thanks in advance,
Johi.
Update:
I have a hunch (from debgging the .mif files generated by quartus from the .txt initialization files that depth needs to be 25 and widt 640 = 8*80
I will try this and come with an update.
Johi.
Conclusion:
initializing a 2 d array using a .mif file works for a 2d array:
Example:
// char mem /*(* ram_init_file = "DE0_CV_SCREENCHAR.mif" *)*/ reg charMem; // color mem (* ram_init_file = "DE0_CV_SCREENCOL.mif" *) reg colMem; // color mem (* ram_init_file = "DE0_CV_SCREENPAL.mif" *) reg palMem
I added the .mif files for these initializations.
initializing a 1 d array also works.
// helper variabeles to read .txt file:
reg [7:0] charMemTmp[2000];
reg [7:0] colMemTmp[2000];
reg [3:0] palMemTmp[48];
//-------------------------------------------------------- // initialize char memory (this statement will be synthetisised): initial begin $readmemh("DE0_CV_SCREENCHAR.txt",charMemTmp); $readmemh("DE0_CV_SCREENCOL.txt" ,colMemTmp); $readmemh("DE0_CV_SCREENPAL.txt" ,palMemTmp); end
In the zip file, all .mif and .txt are included. And also a .XLS with macro's to generate these files.
Johi.
rramo10
Thank you for sharing!
