I have a piece of VHDL which renders to 299 LEs MAX II,and quartus 8.0detects the (carry) chain of a and/xor impleented full adder, with extra contol signals to select just the xr part, te and shifted left one part (two exta iputs to first half adder layer) and an extra contro to do a total bit and of al bits (in the second alf adder layer), but the routing is not using the quick intercell route designed fo carriees.
Is there any way of using genric VHDL to force/suggest that the chain be routed so? cheers jackoLink Copied
From your post, I can't see clearly that the router is performing poor with the said design, particularly wasting resources. Can you give a minimal code example that illustrates your request?
Hi
The router is working, it seems to spot the 32 bit chain, although with the chain a carry may propergate in a loop upto 48 bits. I just don't understand why the signal called 'carry' is widely distributed, and can find no evidence of the special carry routing between LEs being used. Is an fmax of 17MHz in C5 MAX II with a 32 bit carry chain expected, do the altera megafunction adder primitives use carry look ahead? This is not majorly serious, as the UFM osc is well within fmax, its just for possible extended functionality for other people who may choose to use http://nibz.googlecode.com as a compact 23% of MAX II 1270 processor. At the moment I am adding a registered read signal RRD_I, so that standard WISHBONE bus behaviour can be used when it is '0' (i.e. no read delay). I was just wondering if there was a way in VHDL of inserting a CARRY buffer primitive. Check the code below at the end indicating the carry signal, which is the critcal path. process(ir, c, q, DAT_I) -- alu process begin case ir(1 DOWNTO 0) is when "00" => -- first row of half adders x0 <= c&q; a0 <= z&z; -- second row of half adders x1 <= x0 xor carry; a1 <= x0 and carry; cin <= '1'; when "01" => -- first row of half adders x0 <= c&q xor z&DAT_I; a0 <= z&z; -- second row of half adders x1 <= x0 xor carry; a1 <= z&z; cin <= '0'; when "10" => -- first row of half adders x0 <= z&z; a0 <= c&q and not(z)&DAT_I; -- second row of half adders x1 <= x0 xor carry; a1 <= x0 and carry; cin <= '0'; when "11" => -- first row of half adders x0 <= c&q xor z&DAT_I; a0 <= c&q and z&DAT_I; -- second row of half adders x1 <= x0 xor carry; a1 <= x0 and carry; cin <= '0'; end case; -- carry calcs ctmp <= a1 or a0; -- IS THERE A WRAPPER TO MAKE THIS BE ROUTED FAST???? carry <= ctmp(2*width-2 DOWNTO 0)&(ctmp(2*width-1) or cin); --sum output qout <= x1(width-1 DOWNTO 0); cout <= x1(2*width-1 DOWNTO width); true <= carry(width); end process; Thanks in advance jacko- Mark as New
Generally, I let Quartus implement my adders and I got sufficient results for my designs.
I would suggest a benchmark between Quartus default implementation and your structural code to get an overview. I have difficulties to determine, if the present code is suitable for MAX II hardware and also understandable by Quartus integrated synthesis. A low level definition of carry chains is possible however, as stated in the MAX II Device Handbook and Quartus Handbook. There is a specific user guide http://www.altera.com/literature/ug/ug_low_level.pdf dealing with low-level primitives in schematic and HDL design entry.
