Does someone know if I can change unused pin attribute, from tri-state to tri-state w/ weak pullup, with ECO? Thanks,Link Copied
Open QUARTUSII, Assignments>Device>Device and pin options>unused pins>as input tri-stated with weak pullup
Sorry, I need to do this without full compilation.
I'm not aware of a method to access unused resources in property editor. If it exists, each unused pin has to be edited individually, which seems to be long-winded operation.
