I'm using Quartus II 9.0 to build a CPLD MAX II bitstream. I need a svf output file that is different in function of the JTAG speed. But by default the speed is set to 10 Mhz. As I do not used a Altera Probe but a program in a microprocessor to program the CPLD by JTAG, I can't go higher than 1Mhz. Is there a way to configure that speed in Quartus II environement ? Thank you in advance for your help.Link Copied
QUARTUSII
File>Covert programming files>options>Divide clock frequency by select a value between 10 and 16 to have a speed b/w .625Mhz to 1 Mhz- Mark as New
The maximum speed setting in a svf-file can be edited by a FREQUENCY statement. Of course a JTAG programmer is free to use a lower speed anyway. So what's the problem, exactly?
