Code compiling errore
Hellow every bidy;
I faced an errore during compilation of my code on modelsim. the errore displayed " cannot index the result of a type conversion. ". and the errore apears in this line
if std_logic_vector(conv_unsigned(ref, 3))(2) = '0' then
How can I solve this problem?
What is the name of the signal you are trying to index into? Surely it is not "std_logic_vector".
Replace "std_logic_vector" with the signal name you are trying to compare to '0'.
Thanks for ur attension Mr ghogerheiden
I replaced the std_logic_vector ststement and the rrrore removed
but now i faced another errore wich is "bSigned <= conv_signed(-conv_integer(b), SIG_WIDTH));"
in this line
can u help me
If you could post more of the code (for instance where you declare bSigned) and the actual error you are seeing it would be helpful.
At a glance though, I'm not sure you can include the minus sign in the statement bSigned <= conv_signed(-conv_integer(b), SIG_WIDTH));
That could be the problem. You may want to convert it to signed first then negate it?
More information would help.
