help!!
I'm creating a code now, which i need to increase the input A,B by 2 after each state.
Example
@s0: A=00000001, B=00000010.
@s1: I want A= 00000011 and B= 00000100.
How do i do it?
And i know there's something wrong with my code, highlighted in red. As i need help for this. Can someone help?
This is code.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.All;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Project3M2A is
Port ( A : in STD_LOGIC_VECTOR (7 downto 0);
B : in STD_LOGIC_VECTOR (7 downto 0);
W : out STD_LOGIC_VECTOR (7 downto 0);
X : out STD_LOGIC_VECTOR (7 downto 0);
Y : out STD_LOGIC_VECTOR (7 downto 0);
Z : out STD_LOGIC_VECTOR (7 downto 0);
LOAD : in STD_LOGIC;
RST : in STD_LOGIC;
CLK : in STD_LOGIC);
end Project3M2A;
architecture Behavioral of Project3M2A is
type state_type is (S0,S1,S2);--,S3,S4,S5,S6,S7,S8,S9,S10);
signal state, state_next: state_type;
signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 16 downto 0);
signal mult_op0,mult_op1: signed (16 downto 0);
signal R1,R2,R3,R4,R5,R6: signed (7 downto 0 );--R3,R4,R5,R6: std_logic_Vector (7 downto 0 );
--signal R5,R6,R7,R8,R9,R10,R11,R12: std_logic_Vector (7 downto 0 );
signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0);
signal prod: signed (33 downto 0);
begin
P1: process(clk,rst) is
begin
if rst='0' then
state<=S0;
r1 <= (others => '0');
r2 <= (others => '0');
r3 <= (others => '0');
r4 <= (others => '0');
r5 <= (others => '0');
r6 <= (others => '0');
--r7 <= (others => '0');
--r8 <= (others => '0');
--r9 <= (others => '0');
--r10 <= (others => '0');
--r11 <= (others => '0');
--r12 <= (others => '0');
--r6 <= (others => '0');
elsif(clk'event and clk='1') then
state <=state_next; -- next state update
r1<=r1_next;-- update next state at rising edge of clk
r2<=r2_next;
r3<=r3_next;
r4<=r4_next;
r5<=r5_next;
r6<=r6_next;
--r7<=r7_next;
--r8<=r8_next;
--r9<=r9_next;
--r10<=r10_next;
--r11<=r11_next;
--r12<=r12_next;
end if;
end process P1;
P2: process (load, state,r1,r2,r3,r4,r5,r6, A,B)
begin
r1_next<=r1;-- keep previous data if not updated
r2_next<=r2;
r3_next<=r3;
r4_next<=r4;
r5_next<=r5;
r6_next<=r6;
--r7_next<=r7;
--r8<=r8_next;
--r9<=r9_next;
--r10<=r10_next;
--r11<=r11_next;
--r12<=r12_next;
--complete<='0';
case state is
when S0 => if load ='1' then
r1_next<= signed (A(7 downto 0));
r2_next<= signed (B(7 downto 0));
state_next<=S1;
--complete<='1';
else
state_next<=S0;
end if;
when S1=>
r3_next<=signed (A(7 downto 1)& "0");
r4_next<=signed (B(7 downto 1)& "0");
state_next<= S2;
when S2=>
r5_next<=signed (A(7 downto 2)& "00");
r6_next<=signed (B(7 downto 2)& "00");
state_next<=S0;
end case;
end process p2;
end Behavioral;
The next signals all append 0 to the bottom of the word. Therefore not really doing a lot.
if you want to increment by 2, why not write:
r3_next <= signed(A) + 2;
--- Quote Start ---
--- Quote End ---
library IEEE;
--library UNISIM;
COMPLETE: out STD_LOGIC;
RST : in STD_LOGIC;
end Project3M2A;
type state_type is (S0,S1,S2,S3,S4,S5,S6);--,S3,S4,S5,S6,S7,S8,S9,S10);
signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 7 downto 0);
signal mult1,mult2,mult3,mult4: signed (7 downto 0);
signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12: signed (7 downto 0 );--R3,R4,R5,R6: std_logic_Vector (7 downto 0 );
signal R13,R14,R15,R16,R17,R18,R19,R20: signed (7 downto 0 ); -- Registers for doing X and +
signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0);
signal R13_next,R14_next,R15_next: signed( 7 downto 0);
signal prod1,prod2,prod3: signed (7 downto 0);
begin
begin
if rst='0' then
state<=S0;
r2<=r2_next;
r3<=r3_next;
r4<=r4_next;
r5<=r5_next;
r6<=r6_next;
r7<=r7_next;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
end if;
end process P1;
P2: process (load, state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14, A,B)
begin
r2_next<=r2;
r3_next<=r3;
r4_next<=r4;
r5_next<=r5;
r6_next<=r6;
r7_next<=r7;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
complete<='0';
case state is
state_next<=S1;
complete<='1';
else
state_next<=S0;
end if;
when S1=> if load ='1' then
r3_next<=signed (A) +2;
r4_next<=signed (B) +2;
state_next<= S2;
--complete<='1';
else
state_next<=S1;
end if;
when S2=> if load ='1' then
r5_next<=signed (r3_next)+2;
r6_next<=signed (r4_next)+2;
state_next<=S3;
else
state_next<=S2;
end if;
when S3=> if load ='1' then
r7_next<=signed (r5_next)+2;
r8_next<=signed (r6_next)+2;
state_next<= S4;
else
state_next<=S3;
end if;
when S4=> if load ='1' then
r9_next<=signed (r7_next)+2;
r10_next<=signed (r8_next)+2;
state_next<=S5;
else
state_next<=S4;
end if;
when S5=> if load ='1' then
r11_next<=signed (r9_next)+2;
r12_next<=signed (r10_next)+2;
state_next<=S6;
else
state_next<=S5;
end if;
when S6=>
r13_next<=prod1;
r14_next<=prod2;
state_next<=S0;
end case;
end process p2;
CSA1: prod1 <= mult1*mult2;
CSA2: prod2<= mult3*mult4;
P3: process( state,r1,r2,r3,r4,r13,r14)
begin
case state is
when S6=>
mult1 <=signed (A); --R1,A1
mult2 <=signed (B); --R2,A2
when others =>
mult3<= r3; --R3
mult4 <=r4; -- R4
end case;
end process P3;
W<= std_logic_vector(prod1);
end Behavioral;
I want to multiply them together R1*R2. How do i do it? my testbench doesn't show any waveform
op <= (r3_next+2) * (r4_next+2);
--- Quote Start ---
--- Quote End ---
I couldn't get any output after doing what you have said.
the following is my code
library IEEE;
--library UNISIM;
RST : in STD_LOGIC;
end Project3M2A;
begin
begin
if rst='0' then
state<=S0;
r2<=r2_next;
r3<=r3_next;
r4<=r4_next;
r5<=r5_next;
r6<=r6_next;
r7<=r7_next;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
end if;
end process P1;
begin
r2_next<=r2;
r3_next<=r3;
r4_next<=r4;
r5_next<=r5;
r6_next<=r6;
r7_next<=r7;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
complete<='0';
case state is
state_next<=S1;
complete<='1';
else
state_next<=S0;
end if;
state_next<= S2;
--complete<='1';
else
state_next<=S1;
end if;
state_next<=S3;
else
state_next<=S2;
end if;
state_next<= S4;
else
state_next<=S3;
end if;
state_next<=S5;
else
state_next<=S4;
end if;
state_next<=S6;
else
state_next<=S5;
end if;
when S6=>
r13_next<=prod1;
r14_next<=prod2;
state_next<=S0;
end case;
end process p2;
begin
case state is
when S6=>
mult1 <=signed (r1_next); --R1,A1
mult2 <=signed (r2_next); --R2,A2
when others =>
mult3<= r3_next; --R3
mult4 <=r4_next; -- R4
end case;
end process P3;
end Behavioral;
Output from what?
Have you got a testbench?
Its not exactly clear what you're trying to do from the decription in the first post. It sounds like a simple adder to me - but you have some very complicated code..
I'm actually trying to do a matrix multiplication. But currently doing step by step and am stucked.
what if i want at S6 to have the multiplication of R1_NEXT AND R2_NEXT. This value is store in another register called R13_NEXT.
the value of R13_next does not show in my waveform. It is undefined.
when S6=> if load='1' then
r13_next<=(r1_next)*(r2_next);
state_next<=S0;
else
state_next<=S6;
END IF;
My test bench code:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
--USE ieee.numeric_std.ALL;
ENTITY Project3M2A_TBW IS
END Project3M2A_TBW;
ARCHITECTURE behavior OF Project3M2A_TBW IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT Project3M2A
PORT(
A : IN std_logic_vector(7 downto 0);
B : IN std_logic_vector(7 downto 0);
W : OUT std_logic_vector(7 downto 0);
X : OUT std_logic_vector(7 downto 0);
Y : OUT std_logic_vector(7 downto 0);
Z : OUT std_logic_vector(7 downto 0);
LOAD : IN std_logic;
COMPLETE: OUT std_logic;
RST : IN std_logic;
CLK : IN std_logic
END COMPONENT;
--Inputs
signal A : std_logic_vector(7 downto 0) := (others => '0');
signal B : std_logic_vector(7 downto 0) := (others => '0');
signal LOAD : std_logic := '0';
signal RST : std_logic := '0';
signal CLK : std_logic := '0';
--Outputs
signal W : std_logic_vector(7 downto 0);
signal X : std_logic_vector(7 downto 0);
signal Y : std_logic_vector(7 downto 0);
signal Z : std_logic_vector(7 downto 0);
signal COMPLETE: std_logic :='0';
-- Clock period definitions
constant CLK_period : time := 40 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: Project3M2A PORT MAP (
A => A,
B => B,
W => W,
X => X,
Y => Y,
Z => Z,
LOAD => LOAD,
RST => RST,
CLK => CLK
A<="00000001";
B<="00000010";
load<=not load after 40ns;
-- Clock process definitions
CLK_process :process
begin
CLK <= '0';
wait for CLK_period/2;
CLK <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
rst<='0';
wait for 60ns;
rst<='1';
wait for 100ns;
wait;
end process;
END;
This sounds like a good load of debugging is in order.
If r13_next is undefined, then the signals driving it are probably undefined. Trace them back to source.
Well, when i put this, R13_NEXT shows all zero
r13_next<=signed ((r1_next)*(r2_next));
when i put this, r13_next shows undefined
r13_next<=((r1_next)*(r2_next));
I got the value when i put this code
since i put R1_next as "00000001" and R2_next as "00000010";
the multiplied value is " 00000000"..
How do i do the multiplication in integer form?
Are you sure you're in the correct state to do that multiplication.
00000001 * 00000010 = 00000010
From your testebench LOAD toggles in line with the clock - I highly suggest making load synchronous to the clock.
--- Quote Start ---
--- Quote End ---
YES. After loading the values into the system. I want to use r1 which has value of 1 multiply with r2 which has value of 2. But since my r1&r2 is signed number. When doing
R13= signed(r1*r2.) I get 00000000 instead of the value of the value 00000010 that i want. Because it did a binary multiplication.
How do i make it into integer multiplication.
And how do i mske load synchronous to clock
library IEEE;
--library UNISIM;
generic(lower: integer:=0; upper:integer:=127);
RST : in STD_LOGIC;
end Project3M2A;
type state_type is (S0,S1,S2,S3,S4,S5);--,S3,S4,S5,S6,S7,S8,S9,S10);
signal mult1,mult2,mult3,mult4,mult5, mult6: signed (7 downto 0);
signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12: signed( 7 downto 0);
signal R13,R14,R15: integer range lower to upper;
--signal R13,R14,R15,R16,R17,R18,R19,R20: signed (7 downto 0 ); -- Registers for doing X and +
signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: signed( 7 downto 0);--,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0);
signal R13_next,R14_next,R15_next: integer range lower to upper;
signal sum1,sum2: signed (7 downto 0);
begin
begin
if rst='0' then
state<=S0;
--r13 <= (others => '0');
--r14 <= (others => '0');
--r15 <= (others => '0');
elsif(clk'event and clk='1' and load='1') then
state <= S1;
r2<=r2_next;
r3<=r3_next;
r4<=r4_next;
r5<=r5_next;
r6<=r6_next;
r7<=r7_next;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
--r13<=r13_next;
--r14<=r14_next;
--r15<=r15_next;
end if;
end process P1;
P2: process (load,state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,A,B)
begin
r2_next<=r2;
r3_next<=r3;
r4_next<=r4;
r5_next<=r5;
r6_next<=r6;
r7_next<=r7;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
r15<=r15_next;
complete<='0';
case state is
when S0 =>
state_next<=S1;
when S1=>
r3_next<=r1_next +2;
r4_next<=r2_next +2;
r13_next <= to_integer(r1_next);
r14_next <= to_integer(r2_next);
state_next<= S2;
complete<='1';
when S2=>
r15_next<= to_integer (r3_next);
r5_next<= r3_next+2;
r6_next<= r4_next+2;
state_next<=S3;
I tried to change signed value to integer but the value is wrong.. FOR R1_NEXT is declared as "00000001" and R2_NEXT declared as "00000010"
But after i change it to integer it shows that R1_NEXT IS 1, R2_NEXT IS 10. HELP.... i want it to become decimal number. any clues on how i can do it?
right click on the signal in modelsim
goto radix -> decimal.
If it's still 10 - there is a problem in your code - and YOU need to debug it.
--- Quote Start ---
--- Quote End ---
well, apparantly, i can use + but now *
r13_next <= (unsigned(A) + unsigned(B)) --> gives me value of 3
r13_next <= (unsigned(A) *unsigned(B)) --> gives me value of undefine
Please post a copy of the waveform.
Also, why not try making a smaller file.
r13_next <= (unsigned(A) *unsigned( B ) );
Will work just fine. There is clearly something wrong elsewhere in the code if you are getting a 'U' output.
You need to debug the driving values.
this is my waveformhttp://www.alteraforum.com/forum/attachment.php?attachmentid=9698&stc=1
this is my test bench
PORT(
-- P : INOUT std_logic_vector(7 downto 0);
RST : IN std_logic;
CLK : IN std_logic
END COMPONENT;
--Inputs
--Outputs
BEGIN
A => A,
B => B,
W => W,
X => X,
Y => Y,
Z => Z,
LOAD => LOAD,
RST => RST,
CLK => CLK
A<="00000001";
B<="00000010";
load<=not load after 10ns;
begin
CLK <= '0';
wait for CLK_period/4;
CLK <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
rst<='0';
wait for 5ns;
rst<='1';
wait for 10ns;
wait;
end process;
END;
Could it be the clock problem?
http://www.alteraforum.com/forum/attachment.php?attachmentid=9699&stc=1
This waveforms shows that after i did this ------ r13_next <=signed (signed(r1_next)* signed(r2_next));
it gave me output 0 is because it did binary AND operation?
how do i make it to give me the ans 2.
supposed to give me ans of (1*2) = 2.
Now try adding r1_next, r2_next and state to your waveform. how do you expect to debug without the whole picture?
I dont even know what code you're using now.
If you post code, please use code tags.
This is my code....---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Project3M2A is --generic(lower: integer:=1; upper:integer:=127); Port ( A : in STD_LOGIC_VECTOR (7 downto 0); B : in STD_LOGIC_VECTOR (7 downto 0); W : out STD_LOGIC_VECTOR (7 downto 0); X : out STD_LOGIC_VECTOR (7 downto 0); Y : out STD_LOGIC_VECTOR (7 downto 0); Z : out STD_LOGIC_VECTOR (7 downto 0); LOAD : in STD_LOGIC; COMPLETE: out STD_LOGIC; RST : in STD_LOGIC; CLK : in STD_LOGIC); end Project3M2A; architecture Behavioral of Project3M2A is type state_type is (S0,S1,S2,S3,S4,S5,S6,S7);--,S3,S4,S5,S6,S7,S8,S9,S10); signal state, state_next: state_type; signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12,R13,R14,R15: signed( 7 downto 0); signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0);--,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0); begin P1: process(clk,rst) is begin if rst='0' then state<=S0; r1 <= (others => '0'); r2 <= (others => '0'); r3 <= (others => '0'); r4 <= (others => '0'); r5 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); r8 <= (others => '0'); r9 <= (others => '0'); r10 <= (others => '0'); r11 <= (others => '0'); r12 <= (others => '0'); r13 <= (others => '0'); r14 <= (others => '0'); --r15 <= (others => '0'); elsif(clk'event and clk='1' and load='1') then state <= S1; state <=state_next; -- next state update r1<=r1_next;-- update next state at rising edge of clk r2<=r2_next; r3<=r3_next; r4<=r4_next; r5<=r5_next; r6<=r6_next; r7<=r7_next; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; --r15<=r15_next; end if; end process P1; P2: PROCESS(load,state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,A,B) begin case state is when S0 => r1_next<= SIGNED(A(7 downto 0)); r2_next<= SIGNED(B(7 downto 0)); state_next<=S1; when S1=> r3_next<=signed (A) +2; r4_next<=signed (B)+2; state_next<= S2; complete<='1'; when S2=> r5_next<= signed (r3_next)+2; r6_next<= signed (r4_next)+2; state_next<=S3; when S3=> r7_next<=signed (r5_next)+2; r8_next<=signed (r6_next)+2; state_next<= S4; when S4=> r9_next<=signed (r7_next)+2; r10_next<=signed (r8_next)+2; state_next<=S5; when S5=> r11_next<=signed (r9_next)+2; r12_next<=signed (r10_next)+2; state_next<=S6; when S6 => r13_next <=signed (signed(r1_next)* signed(r2_next)); --r14_next <= r3_next*r4_next; --r15_next <= r5_next*r6_next; state_next<=S7; when S7 => r14_next <=signed(signed(r3_next)* signed (r4_next)); state_next<=S0; end case; end process P2; W<= std_logic_vector(signed (r13_next)); end Behavioral;
this is my test bench code
-------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; --use ieee.std_logic_arith.all; --USE ieee.std_logic_signed.ALL; --USE ieee.std_logic_unsigned.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values USE ieee.numeric_std.ALL; ENTITY Project3M2A_TBW IS END Project3M2A_TBW; ARCHITECTURE behavior OF Project3M2A_TBW IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT Project3M2A PORT( A : IN std_logic_vector(7 downto 0); B : IN std_logic_vector(7 downto 0); W : OUT std_logic_vector(7 downto 0); X : OUT std_logic_vector(7 downto 0); Y : OUT std_logic_vector(7 downto 0); Z : OUT std_logic_vector(7 downto 0); -- P : INOUT std_logic_vector(7 downto 0); LOAD : IN std_logic; COMPLETE: OUT std_logic; RST : IN std_logic; CLK : IN std_logic ); END COMPONENT; --Inputs signal A : std_logic_vector(7 downto 0) := (others => '0'); signal B : std_logic_vector(7 downto 0) := (others => '0'); signal LOAD : std_logic := '0'; signal RST : std_logic := '0'; signal CLK : std_logic := '0'; --Outputs signal W : std_logic_vector(7 downto 0); signal X : std_logic_vector(7 downto 0); signal Y : std_logic_vector(7 downto 0); signal Z : std_logic_vector(7 downto 0); signal COMPLETE: std_logic :='0'; -- Clock period definitions constant CLK_period : time := 50 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: Project3M2A PORT MAP ( A => A, B => B, W => W, X => X, Y => Y, Z => Z, LOAD => LOAD, RST => RST, CLK => CLK ); A<="00000001"; B<="00000010"; load<=not load after 40ns; -- Clock process definitions CLK_process :process begin CLK <= '0'; wait for CLK_period/2; CLK <= '1'; wait for CLK_period/2; end process; -- Stimulus process stim_proc: process begin rst<='0'; wait for 5ns; rst<='1'; wait for 10ns; wait; end process; END;
This is my waveform http://www.alteraforum.com/forum/attachment.php?attachmentid=9701&stc=1
i need to have r13_next to be = 2.. but its showing zero in the waveform
Im not sure exactly what you're simulating, because your code has an error:
r13_next is only 8 bits. r1_next*r2_next gives a 16 bit result.
When modifed to
r13_next <=resize (r1_next* r2_next, 8);
It works just fine
OMG, THANKS TRICKY...
You are my savior!!
