I'm creating a code now, which i need to increase the input A,B by 2 after each state.
Example @s0: A=00000001, B=00000010. @s1: I want A= 00000011 and B= 00000100. How do i do it? And i know there's something wrong with my code, highlighted in red. As i need help for this. Can someone help? This is code. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.All; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Project3M2A is Port ( A : in STD_LOGIC_VECTOR (7 downto 0); B : in STD_LOGIC_VECTOR (7 downto 0); W : out STD_LOGIC_VECTOR (7 downto 0); X : out STD_LOGIC_VECTOR (7 downto 0); Y : out STD_LOGIC_VECTOR (7 downto 0); Z : out STD_LOGIC_VECTOR (7 downto 0); LOAD : in STD_LOGIC; RST : in STD_LOGIC; CLK : in STD_LOGIC); end Project3M2A; architecture Behavioral of Project3M2A is type state_type is (S0,S1,S2);--,S3,S4,S5,S6,S7,S8,S9,S10); signal state, state_next: state_type; signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 16 downto 0); signal mult_op0,mult_op1: signed (16 downto 0); signal R1,R2,R3,R4,R5,R6: signed (7 downto 0 );--R3,R4,R5,R6: std_logic_Vector (7 downto 0 ); --signal R5,R6,R7,R8,R9,R10,R11,R12: std_logic_Vector (7 downto 0 ); signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0); signal prod: signed (33 downto 0); begin P1: process(clk,rst) is begin if rst='0' then state<=S0; r1 <= (others => '0'); r2 <= (others => '0'); r3 <= (others => '0'); r4 <= (others => '0'); r5 <= (others => '0'); r6 <= (others => '0'); --r7 <= (others => '0'); --r8 <= (others => '0'); --r9 <= (others => '0'); --r10 <= (others => '0'); --r11 <= (others => '0'); --r12 <= (others => '0'); --r6 <= (others => '0'); --r7 <= (others => '0'); elsif(clk'event and clk='1') then state <=state_next; -- next state update r1<=r1_next;-- update next state at rising edge of clk r2<=r2_next; r3<=r3_next; r4<=r4_next; r5<=r5_next; r6<=r6_next; --r7<=r7_next; --r8<=r8_next; --r9<=r9_next; --r10<=r10_next; --r11<=r11_next; --r12<=r12_next; end if; end process P1; P2: process (load, state,r1,r2,r3,r4,r5,r6, A,B) begin r1_next<=r1;-- keep previous data if not updated r2_next<=r2; r3_next<=r3; r4_next<=r4; r5_next<=r5; r6_next<=r6; --r7_next<=r7; --r8<=r8_next; --r9<=r9_next; --r10<=r10_next; --r11<=r11_next; --r12<=r12_next; --complete<='0'; case state is when S0 => if load ='1' then r1_next<= signed (A(7 downto 0)); r2_next<= signed (B(7 downto 0)); state_next<=S1; --complete<='1'; else state_next<=S0; end if; when S1=> r3_next<=signed (A(7 downto 1)& "0"); r4_next<=signed (B(7 downto 1)& "0"); state_next<= S2; when S2=> r5_next<=signed (A(7 downto 2)& "00"); r6_next<=signed (B(7 downto 2)& "00"); state_next<=S0; end case; end process p2; end Behavioral;Link Copied
The next signals all append 0 to the bottom of the word. Therefore not really doing a lot.
if you want to increment by 2, why not write: r3_next <= signed(A) + 2;- Mark as New
--- Quote Start --- The next signals all append 0 to the bottom of the word. Therefore not really doing a lot. if you want to increment by 2, why not write: r3_next <= signed(A) + 2; --- Quote End --- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.All; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Project3M2A is Port ( A : in STD_LOGIC_VECTOR (7 downto 0); B : in STD_LOGIC_VECTOR (7 downto 0); W : out STD_LOGIC_VECTOR (7 downto 0); X : out STD_LOGIC_VECTOR (7 downto 0); Y : out STD_LOGIC_VECTOR (7 downto 0); Z : out STD_LOGIC_VECTOR (7 downto 0); LOAD : in STD_LOGIC; COMPLETE: out STD_LOGIC; RST : in STD_LOGIC; CLK : in STD_LOGIC); end Project3M2A; architecture Behavioral of Project3M2A is type state_type is (S0,S1,S2,S3,S4,S5,S6);--,S3,S4,S5,S6,S7,S8,S9,S10); signal state, state_next: state_type; signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 7 downto 0); signal mult1,mult2,mult3,mult4: signed (7 downto 0); signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12: signed (7 downto 0 );--R3,R4,R5,R6: std_logic_Vector (7 downto 0 ); signal R13,R14,R15,R16,R17,R18,R19,R20: signed (7 downto 0 ); -- Registers for doing X and + signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0); signal R13_next,R14_next,R15_next: signed( 7 downto 0); signal prod1,prod2,prod3: signed (7 downto 0); begin P1: process(clk,rst) is begin if rst='0' then state<=S0; r1 <= (others => '0'); r2 <= (others => '0'); r3 <= (others => '0'); r4 <= (others => '0'); r5 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); r8 <= (others => '0'); r9 <= (others => '0'); r10 <= (others => '0'); r11 <= (others => '0'); r12 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); elsif(clk'event and clk='1') then state <=state_next; -- next state update r1<=r1_next;-- update next state at rising edge of clk r2<=r2_next; r3<=r3_next; r4<=r4_next; r5<=r5_next; r6<=r6_next; r7<=r7_next; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; end if; end process P1; P2: process (load, state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14, A,B) begin r1_next<=r1;-- keep previous data if not updated r2_next<=r2; r3_next<=r3; r4_next<=r4; r5_next<=r5; r6_next<=r6; r7_next<=r7; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; complete<='0'; case state is when S0 => if load ='1' then r1_next<= signed (A(7 downto 0)); r2_next<= signed (B(7 downto 0)); state_next<=S1; complete<='1'; else state_next<=S0; end if; when S1=> if load ='1' then r3_next<=signed (A) +2; r4_next<=signed (B) +2; state_next<= S2; --complete<='1'; else state_next<=S1; end if; when S2=> if load ='1' then r5_next<=signed (r3_next)+2; r6_next<=signed (r4_next)+2; state_next<=S3; else state_next<=S2; end if; when S3=> if load ='1' then r7_next<=signed (r5_next)+2; r8_next<=signed (r6_next)+2; state_next<= S4; else state_next<=S3; end if; when S4=> if load ='1' then r9_next<=signed (r7_next)+2; r10_next<=signed (r8_next)+2; state_next<=S5; else state_next<=S4; end if; when S5=> if load ='1' then r11_next<=signed (r9_next)+2; r12_next<=signed (r10_next)+2; state_next<=S6; else state_next<=S5; end if; when S6=> r13_next<=prod1; r14_next<=prod2; state_next<=S0; end case; end process p2; CSA1: prod1 <= mult1*mult2; CSA2: prod2<= mult3*mult4; P3: process( state,r1,r2,r3,r4,r13,r14) begin case state is when S6=> mult1 <=signed (A); --R1,A1 mult2 <=signed (B); --R2,A2 when others => mult3<= r3; --R3 mult4 <=r4; -- R4 end case; end process P3; W<= std_logic_vector(prod1); end Behavioral; I want to multiply them together R1*R2. How do i do it? my testbench doesn't show any waveform
op <= (r3_next+2) * (r4_next+2);
--- Quote Start --- op <= (r3_next+2) * (r4_next+2); --- Quote End --- I couldn't get any output after doing what you have said. the following is my code library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.All; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Project3M2A is Port ( A : in STD_LOGIC_VECTOR (7 downto 0); B : in STD_LOGIC_VECTOR (7 downto 0); W : out STD_LOGIC_VECTOR (7 downto 0); X : out STD_LOGIC_VECTOR (7 downto 0); Y : out STD_LOGIC_VECTOR (7 downto 0); Z : out STD_LOGIC_VECTOR (7 downto 0); LOAD : in STD_LOGIC; COMPLETE: out STD_LOGIC; RST : in STD_LOGIC; CLK : in STD_LOGIC); end Project3M2A; architecture Behavioral of Project3M2A is type state_type is (S0,S1,S2,S3,S4,S5,S6);--,S3,S4,S5,S6,S7,S8,S9,S10); signal state, state_next: state_type; signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 7 downto 0); signal mult1,mult2,mult3,mult4: signed (7 downto 0); signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12: signed (7 downto 0 );--R3,R4,R5,R6: std_logic_Vector (7 downto 0 ); signal R13,R14,R15,R16,R17,R18,R19,R20: signed (7 downto 0 ); -- Registers for doing X and + signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0); signal R13_next,R14_next,R15_next: signed( 7 downto 0); signal prod1,prod2,prod3: signed (7 downto 0); begin P1: process(clk,rst) is begin if rst='0' then state<=S0; r1 <= (others => '0'); r2 <= (others => '0'); r3 <= (others => '0'); r4 <= (others => '0'); r5 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); r8 <= (others => '0'); r9 <= (others => '0'); r10 <= (others => '0'); r11 <= (others => '0'); r12 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); elsif(clk'event and clk='1') then state <=state_next; -- next state update r1<=r1_next;-- update next state at rising edge of clk r2<=r2_next; r3<=r3_next; r4<=r4_next; r5<=r5_next; r6<=r6_next; r7<=r7_next; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; end if; end process P1; P2: process (load, state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14, A,B) begin r1_next<=r1;-- keep previous data if not updated r2_next<=r2; r3_next<=r3; r4_next<=r4; r5_next<=r5; r6_next<=r6; r7_next<=r7; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; complete<='0'; case state is when S0 => if load ='1' then r1_next<= signed (A(7 downto 0)); r2_next<= signed (B(7 downto 0)); state_next<=S1; complete<='1'; else state_next<=S0; end if; when S1=> if load ='1' then r3_next<=signed (A) +2; r4_next<=signed (B) +2; state_next<= S2; --complete<='1'; else state_next<=S1; end if; when S2=> if load ='1' then r5_next<=signed (r3_next)+2; r6_next<=signed (r4_next)+2; state_next<=S3; else state_next<=S2; end if; when S3=> if load ='1' then r7_next<=signed (r5_next)+2; r8_next<=signed (r6_next)+2; state_next<= S4; else state_next<=S3; end if; when S4=> if load ='1' then r9_next<=signed (r7_next)+2; r10_next<=signed (r8_next)+2; state_next<=S5; else state_next<=S4; end if; when S5=> if load ='1' then r11_next<=signed (r9_next)+2; r12_next<=signed (r10_next)+2; state_next<=S6; else state_next<=S5; end if; when S6=> r13_next<=prod1; r14_next<=prod2; state_next<=S0; end case; end process p2; CSA1: prod1 <= mult1*mult2; CSA2: prod2<= mult3*mult4; P3: process( state,r1,r2,r3,r4,r13,r14) begin case state is when S6=> mult1 <=signed (r1_next); --R1,A1 mult2 <=signed (r2_next); --R2,A2 when others => mult3<= r3_next; --R3 mult4 <=r4_next; -- R4 end case; end process P3; W<= std_logic_vector(prod1); end Behavioral;
Output from what?
Have you got a testbench? Its not exactly clear what you're trying to do from the decription in the first post. It sounds like a simple adder to me - but you have some very complicated code..- Mark as New
I'm actually trying to do a matrix multiplication. But currently doing step by step and am stucked.
what if i want at S6 to have the multiplication of R1_NEXT AND R2_NEXT. This value is store in another register called R13_NEXT. the value of R13_next does not show in my waveform. It is undefined. when S6=> if load='1' then r13_next<=(r1_next)*(r2_next); state_next<=S0; else state_next<=S6; END IF; My test bench code: LIBRARY ieee; USE ieee.std_logic_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --USE ieee.numeric_std.ALL; ENTITY Project3M2A_TBW IS END Project3M2A_TBW; ARCHITECTURE behavior OF Project3M2A_TBW IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT Project3M2A PORT( A : IN std_logic_vector(7 downto 0); B : IN std_logic_vector(7 downto 0); W : OUT std_logic_vector(7 downto 0); X : OUT std_logic_vector(7 downto 0); Y : OUT std_logic_vector(7 downto 0); Z : OUT std_logic_vector(7 downto 0); LOAD : IN std_logic; COMPLETE: OUT std_logic; RST : IN std_logic; CLK : IN std_logic ); END COMPONENT; --Inputs signal A : std_logic_vector(7 downto 0) := (others => '0'); signal B : std_logic_vector(7 downto 0) := (others => '0'); signal LOAD : std_logic := '0'; signal RST : std_logic := '0'; signal CLK : std_logic := '0'; --Outputs signal W : std_logic_vector(7 downto 0); signal X : std_logic_vector(7 downto 0); signal Y : std_logic_vector(7 downto 0); signal Z : std_logic_vector(7 downto 0); signal COMPLETE: std_logic :='0'; -- Clock period definitions constant CLK_period : time := 40 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: Project3M2A PORT MAP ( A => A, B => B, W => W, X => X, Y => Y, Z => Z, LOAD => LOAD, RST => RST, CLK => CLK ); A<="00000001"; B<="00000010"; load<=not load after 40ns; -- Clock process definitions CLK_process :process begin CLK <= '0'; wait for CLK_period/2; CLK <= '1'; wait for CLK_period/2; end process; -- Stimulus process stim_proc: process begin rst<='0'; wait for 60ns; rst<='1'; wait for 100ns; wait; end process; END;- Mark as New
This sounds like a good load of debugging is in order.
If r13_next is undefined, then the signals driving it are probably undefined. Trace them back to source.- Mark as New
Well, when i put this, R13_NEXT shows all zero
when S6=> if load='1' then r13_next<=signed ((r1_next)*(r2_next)); when i put this, r13_next shows undefined when S6=> if load='1' then r13_next<=((r1_next)*(r2_next));- Mark as New
I got the value when i put this code
S6=> if load='1' then r13_next<=signed ((r1_next)*(r2_next)); since i put R1_next as "00000001" and R2_next as "00000010"; the multiplied value is " 00000000".. How do i do the multiplication in integer form?- Mark as New
Are you sure you're in the correct state to do that multiplication.
00000001 * 00000010 = 00000010 From your testebench LOAD toggles in line with the clock - I highly suggest making load synchronous to the clock.- Mark as New
--- Quote Start --- Are you sure you're in the correct state to do that multiplication. 00000001 * 00000010 = 00000010 From your testebench LOAD toggles in line with the clock - I highly suggest making load synchronous to the clock. --- Quote End --- YES. After loading the values into the system. I want to use r1 which has value of 1 multiply with r2 which has value of 2. But since my r1&r2 is signed number. When doing R13= signed(r1*r2.) I get 00000000 instead of the value of the value 00000010 that i want. Because it did a binary multiplication. How do i make it into integer multiplication. And how do i mske load synchronous to clock
library IEEE;
use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.All; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Project3M2A is generic(lower: integer:=0; upper:integer:=127); Port ( A : in STD_LOGIC_VECTOR (7 downto 0); B : in STD_LOGIC_VECTOR (7 downto 0); W : out STD_LOGIC_VECTOR (7 downto 0); X : out STD_LOGIC_VECTOR (7 downto 0); Y : out STD_LOGIC_VECTOR (7 downto 0); Z : out STD_LOGIC_VECTOR (7 downto 0); LOAD : in STD_LOGIC; COMPLETE: out STD_LOGIC; RST : in STD_LOGIC; CLK : in STD_LOGIC); end Project3M2A; architecture Behavioral of Project3M2A is type state_type is (S0,S1,S2,S3,S4,S5);--,S3,S4,S5,S6,S7,S8,S9,S10); signal state, state_next: state_type; signal add1_op0,add1_op1,add2_op0,add2_op1: signed ( 7 downto 0); signal mult1,mult2,mult3,mult4,mult5, mult6: signed (7 downto 0); signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12: signed( 7 downto 0); signal R13,R14,R15: integer range lower to upper; --signal R13,R14,R15,R16,R17,R18,R19,R20: signed (7 downto 0 ); -- Registers for doing X and + signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: signed( 7 downto 0);--,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0);--,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next: std_logic Vector( 7 downto 0); signal R13_next,R14_next,R15_next: integer range lower to upper; signal prod1,prod2,prod3: signed (7 downto 0); signal sum1,sum2: signed (7 downto 0); begin P1: process(clk,rst) is begin if rst='0' then state<=S0; r1 <= (others => '0'); r2 <= (others => '0'); r3 <= (others => '0'); r4 <= (others => '0'); r5 <= (others => '0'); r6 <= (others => '0'); r7 <= (others => '0'); r8 <= (others => '0'); r9 <= (others => '0'); r10 <= (others => '0'); r11 <= (others => '0'); r12 <= (others => '0'); --r13 <= (others => '0'); --r14 <= (others => '0'); --r15 <= (others => '0'); elsif(clk'event and clk='1' and load='1') then state <= S1; state <=state_next; -- next state update r1<=r1_next;-- update next state at rising edge of clk r2<=r2_next; r3<=r3_next; r4<=r4_next; r5<=r5_next; r6<=r6_next; r7<=r7_next; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; --r13<=r13_next; --r14<=r14_next; --r15<=r15_next; end if; end process P1; P2: process (load,state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,A,B) begin r1_next<=r1;-- keep previous data if not updated r2_next<=r2; r3_next<=r3; r4_next<=r4; r5_next<=r5; r6_next<=r6; r7_next<=r7; r8<=r8_next; r9<=r9_next; r10<=r10_next; r11<=r11_next; r12<=r12_next; r13<=r13_next; r14<=r14_next; r15<=r15_next; complete<='0'; case state is when S0 => r1_next<= signed (A(7 downto 0)); r2_next<= signed (B(7 downto 0)); state_next<=S1; when S1=> r3_next<=r1_next +2; r4_next<=r2_next +2; r13_next <= to_integer(r1_next); r14_next <= to_integer(r2_next); state_next<= S2; complete<='1'; when S2=> r15_next<= to_integer (r3_next); r5_next<= r3_next+2; r6_next<= r4_next+2; state_next<=S3; I tried to change signed value to integer but the value is wrong.. FOR R1_NEXT is declared as "00000001" and R2_NEXT declared as "00000010" But after i change it to integer it shows that R1_NEXT IS 1, R2_NEXT IS 10. HELP.... i want it to become decimal number. any clues on how i can do it?- Mark as New
right click on the signal in modelsim
goto radix -> decimal. If it's still 10 - there is a problem in your code - and YOU need to debug it.- Mark as New
--- Quote Start --- right click on the signal in modelsim goto radix -> decimal. If it's still 10 - there is a problem in your code - and YOU need to debug it. --- Quote End --- well, apparantly, i can use + but now * r13_next <= (unsigned(A) + unsigned(B)) --> gives me value of 3 r13_next <= (unsigned(A) *unsigned(B)) --> gives me value of undefine
Please post a copy of the waveform.
Also, why not try making a smaller file. r13_next <= (unsigned(A) *unsigned( B ) ); Will work just fine. There is clearly something wrong elsewhere in the code if you are getting a 'U' output. You need to debug the driving values.- Mark as New
this is my waveformhttp://www.alteraforum.com/forum/attachment.php?attachmentid=9698&stc=1
this is my test bench ARCHITECTURE behavior OF Project3M2A_TBW IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT Project3M2A PORT( A : IN std_logic_vector(7 downto 0); B : IN std_logic_vector(7 downto 0); W : OUT std_logic_vector(7 downto 0); X : OUT std_logic_vector(7 downto 0); Y : OUT std_logic_vector(7 downto 0); Z : OUT std_logic_vector(7 downto 0); -- P : INOUT std_logic_vector(7 downto 0); LOAD : IN std_logic; COMPLETE: OUT std_logic; RST : IN std_logic; CLK : IN std_logic ); END COMPONENT; --Inputs signal A : std_logic_vector(7 downto 0) := (others => '0'); signal B : std_logic_vector(7 downto 0) := (others => '0'); signal LOAD : std_logic := '0'; signal RST : std_logic := '0'; signal CLK : std_logic := '0'; --Outputs signal W : std_logic_vector(7 downto 0); signal X : std_logic_vector(7 downto 0); signal Y : std_logic_vector(7 downto 0); signal Z : std_logic_vector(7 downto 0); signal COMPLETE: std_logic :='0'; -- Clock period definitions constant CLK_period : time := 40 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: Project3M2A PORT MAP ( A => A, B => B, W => W, X => X, Y => Y, Z => Z, LOAD => LOAD, RST => RST, CLK => CLK ); A<="00000001"; B<="00000010"; load<=not load after 10ns; -- Clock process definitions CLK_process :process begin CLK <= '0'; wait for CLK_period/4; CLK <= '1'; wait for CLK_period/4; end process; -- Stimulus process stim_proc: process begin rst<='0'; wait for 5ns; rst<='1'; wait for 10ns; wait; end process; END; Could it be the clock problem? http://www.alteraforum.com/forum/attachment.php?attachmentid=9699&stc=1 This waveforms shows that after i did this ------ r13_next <=signed (signed(r1_next)* signed(r2_next)); it gave me output 0 is because it did binary AND operation? how do i make it to give me the ans 2. supposed to give me ans of (1*2) = 2.- Mark as New
Now try adding r1_next, r2_next and state to your waveform. how do you expect to debug without the whole picture?
I dont even know what code you're using now. If you post code, please use code tags.- Mark as New
This is my code....----------------------------------------------------------------------------------
library IEEE;
--library UNISIM;
--generic(lower: integer:=1; upper:integer:=127);
RST : in STD_LOGIC;
end Project3M2A;
type state_type is (S0,S1,S2,S3,S4,S5,S6,S7);--,S3,S4,S5,S6,S7,S8,S9,S10);
signal R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12,R13,R14,R15: signed( 7 downto 0);
signal R1_next,R2_next,R3_next,R4_next,R5_next,R6_next,R7_next,R8_next,R9_next,R10_next,R11_next,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0);--,R12_next,R13_next,R14_next,R15_next: signed( 7 downto 0);
begin
begin
if rst='0' then
state<=S0;
state <= S1;
r2<=r2_next;
r3<=r3_next;
r4<=r4_next;
r5<=r5_next;
r6<=r6_next;
r7<=r7_next;
r8<=r8_next;
r9<=r9_next;
r10<=r10_next;
r11<=r11_next;
r12<=r12_next;
r13<=r13_next;
r14<=r14_next;
--r15<=r15_next;
end if;
end process P1;
P2: PROCESS(load,state,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,A,B)
begin
case state is
when S0 =>
r1_next<= SIGNED(A(7 downto 0));
r2_next<= SIGNED(B(7 downto 0));
state_next<=S1;
when S1=>
r4_next<=signed (B)+2;
state_next<= S2;
complete<='1';
when S2=>
r5_next<= signed (r3_next)+2;
r6_next<= signed (r4_next)+2;
state_next<=S3;
when S3=>
state_next<= S4;
when S4=>
state_next<=S5;
when S5=>
state_next<=S6;
when S6 =>
--r14_next <= r3_next*r4_next;
--r15_next <= r5_next*r6_next;
state_next<=S7;
when S7 =>
r14_next <=signed(signed(r3_next)* signed (r4_next));
state_next<=S0;
end case;
end process P2;
W<= std_logic_vector(signed (r13_next));
end Behavioral;
LIBRARY ieee;
--use ieee.std_logic_arith.all;
--USE ieee.std_logic_signed.ALL;
--USE ieee.std_logic_unsigned.ALL;
PORT(
RST : IN std_logic;
CLK : IN std_logic
END COMPONENT;
--Inputs
--Outputs
constant CLK_period : time := 50 ns;
BEGIN
A => A,
B => B,
W => W,
X => X,
Y => Y,
Z => Z,
LOAD => LOAD,
RST => RST,
CLK => CLK
A<="00000001";
B<="00000010";
begin
CLK <= '0';
CLK <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
rst<='0';
wait for 5ns;
rst<='1';
wait for 10ns;
wait;
end process;
END;
This is my waveform http://www.alteraforum.com/forum/attachment.php?attachmentid=9701&stc=1 i need to have r13_next to be = 2.. but its showing zero in the waveform
Im not sure exactly what you're simulating, because your code has an error:
r13_next <=signed (signed(r1_next)* signed(r2_next)); r13_next is only 8 bits. r1_next*r2_next gives a 16 bit result. When modifed to r13_next <=resize (r1_next* r2_next, 8); It works just fine- Mark as New
OMG, THANKS TRICKY...
You are my savior!!- Subscribe to RSS Feed
