17252 Discussions
Comparison with 0 or 1, to detect high impedence
I know that its not allowed to compare with 'X' or 'Z' in a synthesizable VHDL code. But is it allowed to write a code in which I compare a signal to '0' or '1' to detect an 'Z' and suspend the operation? The code is as follows:
process(clk)
begin
if rising_edge(clk ) then
if(rst = '0') then
reg_0 <= (others => 'Z');
elsif(btf_start = '1') then
reg_0 <= "ZZ" & frame_in;
elsif(t_btf_finish = '1') then
end if;
end if;
end process;
process(clk)
begin
if rising_edge(clk) then
if(reg_0(0) = '0' or reg_0(0) = '1') then
-- DO SOME OPERATIONS
else
-- DO NOTHING
end if;
end if;
end process;
--- Quote Start ---
--- Quote End ---
Allowed, yes. Meaningful, no.
reg_0(0) = '0' or reg_0(0) = '1' simply compiles to TRUE
Consider how 'Z' state would be detected in hardware and you'll hopefully understand why the code can't work.
Thanks for your reply.
Yes, I understood the problem. But then how does "casez" synthesize?
there is no casez in VHDL.
--- Quote Start ---
--- Quote End ---
Furthermore, the value z in Verilog casez means a don't care value for synthesis, not a test for z state. See 1364.1 ieee standard for verilog register transfer level synthesis
z can't be used in compare expressions in synthesized Verilog, in so far it's the same thing as in VHDL (not surprizing).
I think Quartus doesn't like tristate signals inside FPGA.
Tristate is for pins.
I doesnt mind them - but it will convert the tristates to muxes.
Thanks to all. Now its clear for me.
