Compatibility Q14.1
I have a project I started with Q12 and I always was able to switch back-and forth between Quartus versions.
Recently I started using Q14.1. But since the corresponding Modelsim version behaves strangely I cannot use my scripts there.
So I wanted to go back to 14.0 to simulate. This is however not possible. When I try to open the project in Q14 it tells me
Error (125048): Error reading Quartus II Settings File X.qsf, line 70 Info (125063): set_global_assignment -name QII_AUTO_PACKED_REGISTERS "MINIMIZE AREA"
Should I change the settings, and if so, what do I need to change?
I believe there might be a backward compatibility issue occur here. Since the Quartus II 15.0 has been released, probably you could give it a try. There should be no issue migrating design from 14.1 to 15.0.
Since the error is related to this set_global_assignment -name QII_AUTO_PACKED_REGISTERS "MINIMIZE AREA", how about you remove this option in your qsf before archive to Q12? And try to unarchive it in Q15.0.
Thank you both for your replues, but I have switched to Q15 as soon as it was available, and I have rewritten my scripts. I had forgotten about this thread, else I might have provided this info earlier. I apologize for not updating.
Glad to hear that the Q15 is working fine with you.
Well I had to change my scripts, so I assume 14 would work now too.
Thanks for your sharing. I guess since QII 15.0 is working now, might not need to try with 14.1 because I believe QII 15.0 should have more enhancement and bug fix.
