How i choose the right value for the fmax of a project in order to have correct simulation waveforms?
kostasLink Copied
Classic timing analyzer had been quite obsolate, I recoment you to use the time quest instead
It should be set according to your clock requirement. Find and apply all the clock pins in your design with the intended clock frequency.
