17255 Discussions
check the verilog code of ADC on FPGA
hi all
when i assign LVDS pins to one IO Bank in altera DE1 CycloneII the value of Vccio for that IO bank changed from 3.3 v to 2.5v
what is the reason and which value should i consider for my design?
hi all
The LVDS buffers need to be powered at 2.5V to operate within the designed specification. So if you have some LVDS pins in a bank, its VCCIO must be 2.5V.
--- Quote Start ---
--- Quote End ---
i want to know how analoge signal to digital signal.2.5 v will be 0 and 3.5v ill be 1
when p signal > n signal --> 1
when p signal < n signal --> 0
how much difference is considered 1 or 0?
If output, refer to VOD.
If input, refer to VID.
Example: VID is 100mV. That means the p>n by 100mV is considered "1"
