17253 Discussions
Compatibility of project files created with old Quartus versions
I have to deal with several designs for the EPM7128STC100-7F PLD using Quartus II. They were created using old versions such as Quartus II 9.1 or 4.0 Web Edition. Is it safe to work with the current version of Quartus (the latest one that works with MAX7000 PLDs is 13.0sp1, as I understand it) or is it recommended to use the same version as was used to create the files?
Adrian
Obviously, if you want to mitigate all risks, and it works just fine, stick with the old version.
But I have never had a problem migrating projects from older to newer versions of quartus. I did have some issues migrating from some max-plus2 projects.
You may have problems migrating designs with some IP cores, but Im guessing as it's a MAX, you wont have many of these.
