17040 Discussions
Editing an existing Megafunction
I am trying to edit the the altera_pcie_av_hip_avmm Megafunction to simply change the BAR size field that is established when the Megafunction is generated by the Wizard.
Editing the existing Megafunction seems like the low risk approach. Then I can remove the old Megafunction and replace it with the edited one... connect it in as it was and
re-generate.
The problem I have is I can't find what file I need to edit . There is a check selection for only files generated by the Wizard ... that didn't seem to help.
The altera_pcie_av_hip_avmm comes with the Altera tools when installing ... I can see the altera_pcie_av_hip_avmm when it is selected from a library
from QSYS. -
I also tried generating the altera_pcie_av_hip_avmm from scratch but was only able to find a starting Megafunction that was streaming when I wanted to use the memory-
mapped interface.
Any suggestions appreciated.
I need to change the BAR size since I am constrained by the SOC ( ARM ) memory map in the rc . PCIe memory is mapped to 0x0800_0000 - 0x08FF_FFFF or similar and
I need a BAR size that supports it. Currently the BAR size indicates bit29 and I would like to recuce it to bit28.
I just need to change the BAR size from 256MB down to 128MB ... for some reason the configuration space works but the two BAR's in the sample with the
Arria V starter kit return a status of UR ( unsupported request ) , when I try to read internal memory or DMA status registers that are accessed vie the BAR's
I am in the middle of probing the chipselect decoded by the PCIe mega function to see if the internal memory or DMA slaves are even getting selected which
I suspect they are not.
My other approach is to get the simulation up that I also need to do . The PCIe probe and analyzer ( LeCroy ) indicates the MemRD is going out to the correct address
but we get a completion with no data and status of UR. Is there any config status that would indicate the reason for the UR status ?
Also, when I tried to move the address from 0x0800_0000 to 0x1000_0000 for the internal memory address map in the design, the BAR registers somehow
automatically changed to A(31..29) from A(31.. 28) ... since writing 0xFFFF_FFFF returns 0xE000_0000 when it previously returned 0xF000_0000 from the BAR's
indicating size ...
Any ideas appreciates.
On some research, it seems the COMMAND register of the endpoint , bit 1 needs to be set for the endpoint to respond to memory requests .
I have no device driver active at this time , so that may make sense. I am writing a Lauterbach .cmm script first to exercise the endpoint before
getting a simple device driver going ( Linux ), to work with our exerciser running on Linux.
I am planning to review the simple device drivers for Altera PCIe endpoints with MM to see what basic device configuration takes
place during the pcie_init.
It looks like I can edit or copy an existing Megafunction ... using the Megafunction Wizard, but when I'm done, I don't see how to reference the new function from the QSYS system.
Any ideas? Ideally I would like to copy and existing function , then edit it.
Thanks BCD
